Текущий статус:
Поддержка
Это задача, созданная в поддержку разработки соответствующего модуля.
Merge pull request #57 from sergejey/revert-56-master
Revert "Рефакторинг MQTT: цикл, ускорение обработки и форма настроек"
https://github.com/sergejey/majordomo-mqtt/commit/...
Merge pull request #56 from SmoKE585/master
Merge pull request #55 from aliaksandr-d/master
feat(mqtt): add TLS/SSL encryption with certificate validation options
Navigation improvement
Merge pull request #54 from layet/master
fix(mqtt): Add indexes for perfomance reasons
Update mqtt.class.php
Too long value error fix for MQTT history
Minor updates
Minor updates
Performance and error tracking
Updates
Updates
PATH_WRITE related updates
Extra debug mode added
Merge pull request #53 from Zaitsev-ap/patch-4
Merge pull request #52 from Zaitsev-ap/patch-3
Update cycle_mqtt.php
Merge pull request #51 from whitevast/patch-1
PHP8 update
SOURCE parameter added for linked method call
Detailed logging option added
Fix of old value check (to use REPLACE_LIST if set)
ONLY_NEW_VALUE setting usage for writing into the topic
Update mqtt_search_admin.html
New value check fixed
Processing delay added
Added setting to have delayed processing for repeating values.
Merge pull request #50 from Zaitsev-ap/master
PHP 8.3
Merge pull request #49 from SmoKE585/patch-1
Update action_admin.html
Code style fixes
Code style fixes
Optimizing
Optimizing
Performance optimizing
Merge pull request #48 from london89/patch-2
Merge pull request #47 from london89/patch-1
Merge pull request #46 from london89/master
Возможность не получать непривязанные топики
Merge pull request #44 from SergMicar/master
Ability to view linked method
Remove queue check when not used
Default write method setting
Abiity to set default write method for MQTT
Queue write method
Queue write method
Queue write methoe added to publish to MQTT broker
Merge pull request #38 from tarasfrompir/patch-1
Create mqtt_ua.php
Merge pull request #35 from SmoKE585/master
Новый дизайн
Merge pull request #30 from Zaitsev-ap/patch-2
Update mqtt_search.inc.php
Support of quick navigation to linked object/property
Merge pull request #29 from Anisan/master
setGlobal only for new values
Merge pull request #28 from savenko-egor/patch-1
Fix "Data too long" error.
Usability improvements
Usability update
Usability update
Updates
Updates
Merge pull request #24 from kvazimoda24/patch-1
Исправление записи пустых значений в базу.
Merge pull request #22 from kvazimoda24/master
Исправление работы из подкаталога
Publish API support
Publish API support
Example:
callAPI('/api/module/mqtt','GET',array('publish'=>'path/to/topic','msg'=>'payload'));
Minor fix
Merge pull request #20 from directman66/patch-2
Search by linked object/property/method added.
Merge pull request #18 from zimur/fix_proccessMessage
fix incorrect variable name in processMessage
Merge pull request #15 from Anisan/patch-1
collapse treeview
"Zero" messages fix
Updates
Updates
Unicode topics fix
Revert "Update cycle_mqtt.php"
This reverts commit 3e125b20db09a0d8598ff00ccb439996abfba456.
phpMQTT library update
Data processing
Data processing
Background data processing
Merge pull request #13 from Anisan/master
add support Simple Devices
Merge pull request #12 from thesoultaker48/master
Fixed bug with losing messages from broker
Merge pull request #11 from olehs/master
added ability to set empty values
Merge pull request #10 from olehs/patch-1
Replace list added
Replace list added
Merge pull request #8 from Gelezako/patch-1
Добавление иконки
Merge pull request #5 from olehs/olehs-patch-1
string compare fix & JSON data recursion
JSON data support
JSON data support
Automatically decode JSON data
Автоматическое раскодирование JSON-данных
Merge pull request #4 from olehs/olehs-patch-1
Улучшение отображения пути в сообщениях при древовидном просмотре
Доработки / Updates
AJAX data refresh in admin
