Это общая задача по разработке системы MajorDoMo
Веб-сайт проекта: http://majordomo.smartliving.ru/
Обсуждение задачи на форуме http://majordomo.smartliving.ru/forum/
Тэги: majordomo,поддержка
18.07.2026
Merge pull request #1199 from artt652/phpMQTT-fix
(SergeJey)
Fix unbounded Remaining Length decoder causing OOM; add PHP 8 guards
https://github.com/sergejey/majordomo/commit/79c2e...
01.07.2026
Project domain update
(SergeJey)
https://github.com/sergejey/majordomo/commit/4ce82...
29.06.2026
Merge pull request #1195 from artt652/patch-1
(SergeJey)
fix: array_reverse() error on PHP 8 when LIST is empty
https://github.com/sergejey/majordomo/commit/9b3dc...
26.06.2026
Merge pull request #1194 from artt652/patch-1
(SergeJey)
Улучшение работы Websocket, уменьшение нагрузки на систему
https://github.com/sergejey/majordomo/commit/d07fd...
25.06.2026
Update index.php
(SergeJey)
Update index.php
Security update
https://github.com/sergejey/majordomo/commit/3a175...
19.06.2026
Merge pull request #1189 from artt652/patch-1
(SergeJey)
Add resource check before fwrite in Socket.php
https://github.com/sergejey/majordomo/commit/3db51...
19.06.2026
Merge pull request #1190 from artt652/patch-2
(SergeJey)
Add resource check before socket shutdown
https://github.com/sergejey/majordomo/commit/7dc49...
04.06.2026
Panel badge color fix
(SergeJey)
https://github.com/sergejey/majordomo/commit/3152e...
02.06.2026
Merge pull request #1188 from andrei-trybukhouski/alpha
(SergeJey)
fix: dont use cache for __updated
https://github.com/sergejey/majordomo/commit/ea0d2...
31.05.2026
Merge pull request #1185 from SmoKE585/alpha
(SergeJey)
Улучшения циклов, PHP 8, ошибок, кеша и ВебСокетов
https://github.com/sergejey/majordomo/commit/e6702...
31.05.2026
Merge pull request #1186 from andrei-trybukhouski/alpha
(SergeJey)
feat(objects): add __updated property suffix support
https://github.com/sergejey/majordomo/commit/151e0...
28.05.2026
Merge pull request #1183 from andrei-trybukhouski/alpha
(SergeJey)
Fix line endings
https://github.com/sergejey/majordomo/commit/f349e...
25.05.2026
Update sqlFunctions.class.php
(SergeJey)
https://github.com/sergejey/majordomo/commit/9ef23...
22.05.2026
Merge branch 'alpha' of https://github.com/sergejey/majordomo into alpha
(SergeJey)
https://github.com/sergejey/majordomo/commit/5ed08...
18.05.2026
Merge pull request #1182 from whitevast/alpha
(SergeJey)
PHP 8.4 E_STRICT error fix
https://github.com/sergejey/majordomo/commit/d7946...
22.03.2026
CONNECT: http polling fallback
(SergeJey)
When MQTT is not available, system will try to use HTTP polling as a fallback.
https://github.com/sergejey/majordomo/commit/9778f...
18.03.2026
Presence sensor behavior fix
(SergeJey)
https://github.com/sergejey/majordomo/commit/2d21d...
18.03.2026
Fixes
(SergeJey)
Fixes
11.03.2026
Merge pull request #1181 from whitevast/alpha
(SergeJey)
PHP exception fix
https://github.com/sergejey/majordomo/commit/49e79...
06.03.2026
Merge pull request #1179 from whitevast/alpha
(SergeJey)
PHP8 warning fixes
https://github.com/sergejey/majordomo/commit/f66d9...
21.02.2026
Missing files update
(SergeJey)
https://github.com/sergejey/majordomo/commit/cced5...
18.02.2026
Merge pull request #1176 from whitevast/patch-6
(SergeJey)
Update patterns.class.php
https://github.com/sergejey/majordomo/commit/202f9...
14.02.2026
Update cycle_connect.php
(SergeJey)
https://github.com/sergejey/majordomo/commit/41086...
11.02.2026
DB backup fix
(SergeJey)
DB backup fix
https://github.com/sergejey/majordomo/commit/79a03...
09.02.2026
Fixes
(SergeJey)
Fixes
07.02.2026
XRay improvements
(SergeJey)
XRay improvements
https://github.com/sergejey/majordomo/commit/d102f...
07.02.2026
Update module_edit.inc.php
(SergeJey)
https://github.com/sergejey/majordomo/commit/9a224...
07.02.2026
Update module.class.php
(SergeJey)
Notifications minor update
https://github.com/sergejey/majordomo/commit/a7ce1...
07.02.2026
Online indicator
(SergeJey)
Online indicator
Image for IP address availability indicator
https://github.com/sergejey/majordomo/commit/f6824...
06.02.2026
DB functions update
(SergeJey)
DB functions update
06.02.2026
Update mysqli.class.php
(SergeJey)
https://github.com/sergejey/majordomo/commit/d8fd0...
25.01.2026
Updates
(SergeJey)
Updates
19.01.2026
Updates
(SergeJey)
Updates
13.01.2026
Minor updates
(SergeJey)
Minor updates
https://github.com/sergejey/majordomo/commit/44103...
08.01.2026
Minor improvements
(SergeJey)
Minor improvements
https://github.com/sergejey/majordomo/commit/99d9a...
22.12.2025
Run cycle updates
(SergeJey)
Run cycle updates
https://github.com/sergejey/majordomo/commit/f3a45...
21.12.2025
Updates
(SergeJey)
Updates
21.12.2025
Update startup_maintenance.php
(SergeJey)
https://github.com/sergejey/majordomo/commit/b25b7...
15.12.2025
Updates
(SergeJey)
Updates
13.12.2025
Updates
(SergeJey)
Updates
11.12.2025
Missing files fix
(SergeJey)
Missing files fix
https://github.com/sergejey/majordomo/commit/03016...
10.12.2025
Updates
(SergeJey)
Updates
09.12.2025
Update connect.class.php
(SergeJey)
Allow insecure HTTPs if selected.
https://github.com/sergejey/majordomo/commit/b4e74...
27.11.2025
Minor scripts update
(SergeJey)
https://github.com/sergejey/majordomo/commit/6d3c1...
24.11.2025
WS server fix
(SergeJey)
WS server fix
https://github.com/sergejey/majordomo/commit/a7876...
23.11.2025
Updates
(SergeJey)
Updates
23.11.2025
Merge pull request #1173 from andrei-trybukhouski/ws_fix
(SergeJey)
fix websocket server
https://github.com/sergejey/majordomo/commit/eb8ac...
Обсуждение (3) (1)
07.11.2025
(SergeJey)
https://github.com/sergejey/majordomo/commit/f45e7...
17.10.2025
Merge pull request #1171 from whitevast/alpha
(SergeJey)
Работа над ошибками
https://github.com/sergejey/majordomo/commit/339ca...
16.10.2025
Merge pull request #1170 from whitevast/alpha
(SergeJey)
Изменения в создании свойств объекта
https://github.com/sergejey/majordomo/commit/f5c9c...
30.09.2025
(SergeJey)
https://github.com/sergejey/majordomo/commit/de8ee...
30.09.2025
CONNECT cycle optimization
(SergeJey)
https://github.com/sergejey/majordomo/commit/33523...
23.09.2025
Update ru.php
(SergeJey)
Update ru.php
Web-site link fix
https://github.com/sergejey/majordomo/commit/e716a...
07.09.2025
Contacts update
(SergeJey)
Contacts update
https://github.com/sergejey/majordomo/commit/84161...
04.09.2025
Devices update
(SergeJey)
Devices update
01.09.2025
Update index.php
(SergeJey)
Update index.php
Fix for https://connect.smartliving.ru/ideas/1044.html
https://github.com/sergejey/majordomo/commit/a05ce...
31.08.2025
Devices links update
(SergeJey)
31.08.2025
Update objects.class.php
(SergeJey)
https://github.com/sergejey/majordomo/commit/e2491...
31.08.2025
Merge pull request #1168 from whitevast/patch-7
(SergeJey)
Update general.class.php
https://github.com/sergejey/majordomo/commit/7b524...
30.08.2025
getProperty fix
(SergeJey)
getProperty fix
getProperty fix
https://github.com/sergejey/majordomo/commit/36560...
28.08.2025
Typed values for properties
(SergeJey)
Return of typed values for objects properties
https://github.com/sergejey/majordomo/commit/08724...
15.08.2025
Devices sync fix
(SergeJey)
Devices sync fix
https://github.com/sergejey/majordomo/commit/4deb0...
15.08.2025
Minor updates
(SergeJey)
Minor updates
https://github.com/sergejey/majordomo/commit/578e2...
23.07.2025
Updates
(SergeJey)
Updates
19.07.2025
Minor updates
(SergeJey)
Minor updates
https://github.com/sergejey/majordomo/commit/e9148...
18.07.2025
Merge pull request #1167 from whitevast/alpha
(SergeJey)
Убрано ограничение SAY в 255 символов
https://github.com/sergejey/majordomo/commit/e341c...
17.07.2025
Update api.php
(SergeJey)
Update api.php
https://github.com/sergejey/majordomo/commit/e2982...
10.07.2025
Minor improvements
(SergeJey)
Minor improvements
https://github.com/sergejey/majordomo/commit/a5559...
29.05.2025
Update PHPMailer.php
(SergeJey)
PHP8 fix
https://github.com/sergejey/majordomo/commit/e7df5...
16.05.2025
Minor fix
(SergeJey)
Minor fix
https://github.com/sergejey/majordomo/commit/56326...
22.04.2025
Merge pull request #1163 from whitevast/alpha
(SergeJey)
PHP8 warning fix
https://github.com/sergejey/majordomo/commit/d3efb...
12.04.2025
Refactor array access syntax from curly braces to square brackets in …
(SergeJey)
Refactor array access syntax from curly braces to square brackets in AnimGif and Lexer classes
https://github.com/sergejey/majordomo/commit/ae299...
02.04.2025
Merge pull request #1161 from london89/alpha
(SergeJey)
MODULE_DEVICES and MODULE_CHARTS language fix
https://github.com/sergejey/majordomo/commit/4d653...
05.03.2025
Merge pull request #1162 from whitevast/alpha
(SergeJey)
PHP8
https://github.com/sergejey/majordomo/commit/c19f4...
05.02.2025
Scenes update
(SergeJey)
Scenes update
05.02.2025
Merge pull request #1159 from whitevast/patch-5
(SergeJey)
Update saverestore.class.php
https://github.com/sergejey/majordomo/commit/54d42...
01.02.2025
Code history
(SergeJey)
Code history
Automatic code history tracking with ability to restore previous version
https://github.com/sergejey/majordomo/commit/349dd...
27.01.2025
New loadType: AC
(SergeJey)
New loadType: AC
New loadType for Relays -- Air Conditioner
https://github.com/sergejey/majordomo/commit/83e7e...
22.01.2025
Fixes
(SergeJey)
Fixes
Fix of possible incorrect database saving
https://github.com/sergejey/majordomo/commit/df59b...
10.01.2025
Merge pull request #1157 from tarasfrompir/patch-6
(SergeJey)
Update processCommand.inc.php
https://github.com/sergejey/majordomo/commit/78a79...
10.01.2025
Merge pull request #1155 from whitevast/patch-3
(SergeJey)
https://github.com/sergejey/majordomo/commit/65c9e...
05.01.2025
Merge pull request #1154 from whitevast/patch-2
(SergeJey)
https://github.com/sergejey/majordomo/commit/ac38c...
03.01.2025
Minor updates
(SergeJey)
Minor updates
https://github.com/sergejey/majordomo/commit/eae67...
17.12.2024
Update devices_structure_links.inc.php
(SergeJey)
Ability to add linked actions for Relays
https://github.com/sergejey/majordomo/commit/89d9e...
13.12.2024
FIxes
(SergeJey)
FIxes
11.12.2024
Dimmer logic fix
(SergeJey)
Dimmer logic fix
https://github.com/sergejey/majordomo/commit/d9ed9...
07.12.2024
API update
(SergeJey)
API update
Rooms management added
https://github.com/sergejey/majordomo/commit/dc988...
03.12.2024
Update et.php
(SergeJey)
Update et.php
Estonian language update
https://github.com/sergejey/majordomo/commit/66860...
01.12.2024
Updates
(SergeJey)
Updates
28.11.2024
Thermostat behavior update
(SergeJey)
Minor update
https://github.com/sergejey/majordomo/commit/54f57...
28.11.2024
Update SDimmers_statusUpdated.php
(SergeJey)
https://github.com/sergejey/majordomo/commit/d1894...
28.11.2024
Thermostat fix
(SergeJey)
Thermostat fix
https://github.com/sergejey/majordomo/commit/fd2a0...
27.11.2024
Thermostat device logic update
(SergeJey)
23.11.2024
Create details.html
(SergeJey)
Create details.html
https://github.com/sergejey/majordomo/commit/f30b4...
22.11.2024
Updates
(SergeJey)
Updates
17.11.2024
API updates
(SergeJey)
API updates
Minor API fixes
https://github.com/sergejey/majordomo/commit/31840...
16.11.2024
Merge pull request #1150 from tarasfrompir/patch-4
(SergeJey)
Update devices_edit_settings.html
https://github.com/sergejey/majordomo/commit/c3b0c...
15.11.2024
Merge pull request #1113 from ai91/feature/hisotryaverage
(SergeJey)
Расширение getHistoryAvg возможностью интегрального рассчета среднего значения
https://github.com/sergejey/majordomo/commit/cad46...
12.11.2024
(SergeJey)
New feature: optional getModuleProperty method to read data from the module directly without linked object.
https://github.com/sergejey/majordomo/commit/aaa77...
06.11.2024
SendMail function update
(SergeJey)
SendMail function update + Mail settings section added
https://github.com/sergejey/majordomo/commit/b6f3b...
30.10.2024
Update devices_edit.inc.php
(SergeJey)
Cache fix
https://github.com/sergejey/majordomo/commit/57e02...
27.10.2024
Sub-devices
(SergeJey)
Sub-devices
New concept -- sub-devices for Simple Devices
https://github.com/sergejey/majordomo/commit/9367f...
04.10.2024
callAPI updates
(SergeJey)
callAPI updates
28.09.2024
Update errors.class.php
(SergeJey)
https://github.com/sergejey/majordomo/commit/7fd63...
24.09.2024
Merge pull request #1147 from kvazimoda24/thumb-patch
(SergeJey)
Проблема со слишком длинным именем файла
https://github.com/sergejey/majordomo/commit/78744...
21.09.2024
Linked Doors/Windows for thermostat
(SergeJey)
Ability to set doors/window to turn-off thermostat automatically when open.
https://github.com/sergejey/majordomo/commit/5247e...
19.09.2024
Minor PHP8 updates
(SergeJey)
Minor PHP8 updates
https://github.com/sergejey/majordomo/commit/8e9a0...
17.09.2024
PHP8 updates
(SergeJey)
PHP8 updates
https://github.com/sergejey/majordomo/commit/348b4...
Обсуждение (1) (0)
14.09.2024
Error handling updates
(SergeJey)
https://github.com/sergejey/majordomo/commit/ac216...
12.09.2024
(SergeJey)
https://github.com/sergejey/majordomo/commit/9d090...
11.09.2024
Updates
(SergeJey)
Updates
09.09.2024
Updates
(SergeJey)
Updates
06.09.2024
Updates
(SergeJey)
Updates
24.08.2024
Delete object update
(SergeJey)
Updated object deletion procedure to avoid problem when user tries to delete object that is already removed.
https://github.com/sergejey/majordomo/commit/15536...
16.08.2024
Update api.php
(SergeJey)
Update api.php
https://github.com/sergejey/majordomo/commit/03487...
11.08.2024
Dimmer update
(SergeJey)
Dimmer update
11.08.2024
Updates
(SergeJey)
Updates
API update for new app
https://github.com/sergejey/majordomo/commit/faffa...
08.08.2024
Merge pull request #1137 from whitevast/patch-1
(SergeJey)
https://github.com/sergejey/majordomo/commit/db921...
04.08.2024
API updates
(SergeJey)
API updates
26.07.2024
Better failed db handling
(SergeJey)
Ability to get into admin and restore backup even in case of DB failure.
https://github.com/sergejey/majordomo/commit/16528...
22.07.2024
Create devices_edit_settings_type_devices.html
(SergeJey)
Missing file :)
https://github.com/sergejey/majordomo/commit/fed74...
20.07.2024
Update api.php
(SergeJey)
Update api.php
Ability to update device's title and room
https://github.com/sergejey/majordomo/commit/f3768...
20.07.2024
GroupStates device type added
(SergeJey)
https://github.com/sergejey/majordomo/commit/7ed69...
09.07.2024
Remote access issue fix
(SergeJey)
Issue with incorrect data saved
https://github.com/sergejey/majordomo/commit/cf76b...
08.07.2024
Merge pull request #1135 from whitevast/alpha
(SergeJey)
String - int fixes
https://github.com/sergejey/majordomo/commit/1991f...
03.07.2024
Merge pull request #1134 from Zaitsev-ap/patch-1
(SergeJey)
update class.websocket_client.php
https://github.com/sergejey/majordomo/commit/ee85e...
02.07.2024
Fixes
(SergeJey)
Fixes
26.06.2024
Merge pull request #1133 from whitevast/alpha
(SergeJey)
PHP8 fix
https://github.com/sergejey/majordomo/commit/553a2...
25.06.2024
Merge pull request #1131 from whitevast/alpha
(SergeJey)
PHP8 fixes
https://github.com/sergejey/majordomo/commit/3435f...
16.06.2024
Update settings_search.inc.php
(SergeJey)
PHP 5 capability fix
https://github.com/sergejey/majordomo/commit/430a6...
15.06.2024
Update application.class.php
(SergeJey)
https://github.com/sergejey/majordomo/commit/7234e...
15.06.2024
(SergeJey)
https://github.com/sergejey/majordomo/commit/25f9a...
13.06.2024
(SergeJey)
Authentication issue fix
https://github.com/sergejey/majordomo/commit/255ca...
Обсуждение (1) (0)
12.06.2024
Update settings.html
(SergeJey)
Cancel button remove for settings page.
https://github.com/sergejey/majordomo/commit/ba4fe...
11.06.2024
Updates
(SergeJey)
Updates
31.05.2024
Variable name fix
(SergeJey)
Variable name fix
https://github.com/sergejey/majordomo/commit/324ae...
14.05.2024
Update devices.class.php
(SergeJey)
Do not update KEEP_HISTORY attribute if the property is already added.
https://github.com/sergejey/majordomo/commit/bf33e...
13.05.2024
External access check update
(SergeJey)
08.05.2024
Merge pull request #1126 from ai91/patch-1
(SergeJey)
Проверка доступности интернета через пинг www.google.com (вместо tut.by)
https://github.com/sergejey/majordomo/commit/89994...
04.05.2024
Fix of caching
(SergeJey)
Fix of caching
Fix of memory allocatin problem for cache. New option added to config file to define max value size.
https://github.com/sergejey/majordomo/commit/43096...
19.04.2024
Merge pull request #1124 from whitevast/alpha
(SergeJey)
Fix
https://github.com/sergejey/majordomo/commit/02d23...
15.04.2024
Merge pull request #1122 from Anisan/patch-5
(SergeJey)
increasing the cache value limit
https://github.com/sergejey/majordomo/commit/750b3...
14.04.2024
Merge pull request #1123 from whitevast/alpha
(SergeJey)
Изменения для обновленной версии модуля HomeKit
https://github.com/sergejey/majordomo/commit/0ebc8...
04.04.2024
Merge pull request #1118 from whitevast/patch-6
(SergeJey)
Update homebridgeSendUpdate.inc.php
https://github.com/sergejey/majordomo/commit/73f21...
03.04.2024
Restore/Backup procedure fixes
(SergeJey)
https://github.com/sergejey/majordomo/commit/466ee...
29.03.2024
Merge pull request #1120 from Anisan/patch-4
(SergeJey)
fix get list keys from redis
https://github.com/sergejey/majordomo/commit/528da...
28.03.2024
Merge pull request #1119 from elmax983/master
(SergeJey)
Возвращение к работоспособности методов термостата
https://github.com/sergejey/majordomo/commit/c20e9...
27.03.2024
Updates
(SergeJey)
Updates
18.03.2024
Fix
(SergeJey)
Fix
18.03.2024
Create STempHumSensors.html
(SergeJey)
https://github.com/sergejey/majordomo/commit/da5e3...
Обсуждение (1) (0)
17.03.2024
Backup fix
(SergeJey)
Backup fix
Fixing backup restoring procedure
https://github.com/sergejey/majordomo/commit/ed1bf...
22.02.2024
Fixes
(SergeJey)
Fixes
01.02.2024
Merge pull request #1114 from layet/alpha
(SergeJey)
Authorization does not work with a non-local HTTP proxy
https://github.com/sergejey/majordomo/commit/1ac11...
26.01.2024
Merge pull request #1112 from layet/alpha
(SergeJey)
Add getGlobal/setGlobal JS function with sync request
https://github.com/sergejey/majordomo/commit/5ee1d...
10.01.2024
Main cycle restart fix
(SergeJey)
https://github.com/sergejey/majordomo/commit/a7281...
09.01.2024
Fix for checking updates from GitHub
(SergeJey)
07.01.2024
Merge pull request #1106 from ai91/feature/plans_attributes
(SergeJey)
Модуль "Планы": поддержка обновления аттрибутов через вебсокеты
https://github.com/sergejey/majordomo/commit/0fc2a...
04.12.2023
Dimmer update
(SergeJey)
Dimmer update
29.11.2023
Merge pull request #1104 from whitevast/patch-5
(SergeJey)
Temphum Homebridge
https://github.com/sergejey/majordomo/commit/cf82f...
28.11.2023
Sample device addon structure fix
(SergeJey)
https://github.com/sergejey/majordomo/commit/afa47...
27.11.2023
Filename fix
(SergeJey)
Filename fix
https://github.com/sergejey/majordomo/commit/8bf3e...
19.11.2023
(SergeJey)
https://github.com/sergejey/majordomo/commit/e82f7...
18.11.2023
Minor updates
(SergeJey)
Minor updates
https://github.com/sergejey/majordomo/commit/07917...
16.11.2023
Update jTemplate.class.php
(SergeJey)
https://github.com/sergejey/majordomo/commit/1b981...
15.11.2023
Update thumb.php
(SergeJey)
Update thumb.php
https://github.com/sergejey/majordomo/commit/0662e...
14.11.2023
Update thumb.php
(SergeJey)
Update thumb.php
https://github.com/sergejey/majordomo/commit/3ec3f...
11.11.2023
Scripts auto-link fix
(SergeJey)
Remove auto-linking for scripts
https://github.com/sergejey/majordomo/commit/1167c...
28.10.2023
Admin panel load optmiziation
(SergeJey)
28.10.2023
Scene updates
(SergeJey)
Scene updates
23.10.2023
Optimize operation order fix
(SergeJey)
https://github.com/sergejey/majordomo/commit/9adbf...
Обсуждение (2) (1)
23.10.2023
Merge pull request #1095 from whitevast/patch-3
(SergeJey)
Patch 3
https://github.com/sergejey/majordomo/commit/ed79c...
22.10.2023
Merge pull request #1094 from whitevast/patch-1
(SergeJey)
https://github.com/sergejey/majordomo/commit/14415...
11.10.2023
Motion sensor
(SergeJey)
Motion sensor
07.10.2023
Thermostat update
(SergeJey)
Thermostat update
29.09.2023
Update temphum_links_actions.php
(SergeJey)
https://github.com/sergejey/majordomo/commit/f1429...
27.09.2023
Update scenes.tpl
(SergeJey)
Update scenes.tpl
Write zoom info into console for debug
https://github.com/sergejey/majordomo/commit/150f2...
23.09.2023
Scene scale fix
(SergeJey)
Scene scale fix
21.09.2023
Update scenes.tpl
(SergeJey)
Update scenes.tpl
Fix of scenes zoom
https://github.com/sergejey/majordomo/commit/bffd0...
16.08.2023
Minor updates
(SergeJey)
Minor updates
https://github.com/sergejey/majordomo/commit/bb019...
15.08.2023
Fixes
(SergeJey)
Fixes
15.08.2023
Update scenes.tpl
(SergeJey)
Update scenes.tpl
https://github.com/sergejey/majordomo/commit/feda0...
12.08.2023
Update phpMQTT.php
(SergeJey)
Update phpMQTT.php
https://github.com/sergejey/majordomo/commit/dd544...
09.08.2023
Merge pull request #1081 from whitevast/alpha-1
(SergeJey)
https://github.com/sergejey/majordomo/commit/7e0d8...
28.07.2023
Updates
(SergeJey)
Updates
27.07.2023
(SergeJey)
https://github.com/sergejey/majordomo/commit/5e0b3...
26.07.2023
Update class.websocket_client.php
(SergeJey)
https://github.com/sergejey/majordomo/commit/fe880...
25.07.2023
Updates
(SergeJey)
Updates
15.07.2023
(SergeJey)
https://github.com/sergejey/majordomo/commit/4d285...
15.07.2023
Homebridge sync update
(SergeJey)
https://github.com/sergejey/majordomo/commit/66cbd...
14.07.2023
Update control_modules.class.php
(SergeJey)
https://github.com/sergejey/majordomo/commit/4ff50...
13.07.2023
(SergeJey)
https://github.com/sergejey/majordomo/commit/1509e...
12.07.2023
(SergeJey)
https://github.com/sergejey/majordomo/commit/bb204...
12.07.2023
Update fullchain.pem
(SergeJey)
https://github.com/sergejey/majordomo/commit/68368...
02.07.2023
(SergeJey)
"Forwarding" topic support for CONNECT.
https://github.com/sergejey/majordomo/commit/0c4d4...
30.06.2023
Simple devices
(SergeJey)
Simple devices
Change to addons structure (homebridge sync)
https://github.com/sergejey/majordomo/commit/d706a...
30.06.2023
Updates
(SergeJey)
Updates
29.06.2023
Update parser.class.php
(SergeJey)
SmartyParser update
https://github.com/sergejey/majordomo/commit/5ef2a...
27.06.2023
(SergeJey)
Cloud backup code return
https://github.com/sergejey/majordomo/commit/aab89...
24.06.2023
(SergeJey)
https://github.com/sergejey/majordomo/commit/16b78...
24.06.2023
(SergeJey)
https://github.com/sergejey/majordomo/commit/894b6...
23.06.2023
Update phpMQTT.php
(SergeJey)
Update phpMQTT.php
https://github.com/sergejey/majordomo/commit/6a905...
23.06.2023
Update phpMQTT.php
(SergeJey)
Update phpMQTT.php
https://github.com/sergejey/majordomo/commit/af86c...
22.06.2023
Device actions improvements
(SergeJey)
22.06.2023
Updates
(SergeJey)
Updates
22.06.2023
Merge pull request #1077 from whitevast/patch-7
(SergeJey)
https://github.com/sergejey/majordomo/commit/776d8...
21.06.2023
PHP8 updates
(SergeJey)
PHP8 updates
https://github.com/sergejey/majordomo/commit/52252...
21.06.2023
Merge pull request #1076 from whitevast/patch-6
(SergeJey)
Update common.class.php
https://github.com/sergejey/majordomo/commit/89a89...
21.06.2023
PHP8 updates
(SergeJey)
PHP8 updates
https://github.com/sergejey/majordomo/commit/5e2b3...
21.06.2023
Fixes
(SergeJey)
Fixes
08.06.2023
Updates
(SergeJey)
Updates
Обсуждение (4) (0)
05.06.2023
History cleanup updates
(SergeJey)
https://github.com/sergejey/majordomo/commit/efcb1...
05.06.2023
(SergeJey)
Fix of details not getting passed to the pattern in common context.
https://github.com/sergejey/majordomo/commit/c2ec8...
03.06.2023
Minor updates
(SergeJey)
Minor updates
https://github.com/sergejey/majordomo/commit/ee204...
30.05.2023
Clean-up
(SergeJey)
Clean-up
https://github.com/sergejey/majordomo/commit/0bcaf...
28.05.2023
(SergeJey)
https://github.com/sergejey/majordomo/commit/f829c...
27.05.2023
Code style updates
(SergeJey)
Code style updates
https://github.com/sergejey/majordomo/commit/be1fe...
24.05.2023
Update market.class.php
(SergeJey)
Fix of downloading commercial plugins.
https://github.com/sergejey/majordomo/commit/68c98...
23.05.2023
Merge pull request #1072 from whitevast/patch-5
(SergeJey)
Update xray.class.php
https://github.com/sergejey/majordomo/commit/527f3...
23.05.2023
(SergeJey)
https://github.com/sergejey/majordomo/commit/b08c1...
22.05.2023
Market fix
(SergeJey)
Market fix
https://github.com/sergejey/majordomo/commit/00f17...
19.05.2023
Code style
(SergeJey)
Code style
https://github.com/sergejey/majordomo/commit/2c4a7...
19.05.2023
Code style fixes
(SergeJey)
Code style fixes
https://github.com/sergejey/majordomo/commit/b9e63...
18.05.2023
Code style fixes
(SergeJey)
Code style fixes
https://github.com/sergejey/majordomo/commit/71c63...
16.05.2023
PHP 8 initial support
(SergeJey)
https://github.com/sergejey/majordomo/commit/bc262...
09.04.2023
Patterns fix
(SergeJey)
Patterns fix
https://github.com/sergejey/majordomo/commit/0cf1a...
15.03.2023
Create device_block.html
(SergeJey)
Missing file :)
https://github.com/sergejey/majordomo/commit/d4a90...
14.03.2023
Scenes
(SergeJey)
Scenes
08.03.2023
Patterns update
(SergeJey)
Patterns update
Обсуждение (1) (1)
06.03.2023
Update SMotions_motionDetected.php
(SergeJey)
Motion timeout fix
https://github.com/sergejey/majordomo/commit/2a481...
03.03.2023
Merge pull request #1070 from whitevast/patch-4
(SergeJey)
https://github.com/sergejey/majordomo/commit/aafec...
16.02.2023
Scenes fix
(SergeJey)
Scenes fix
07.02.2023
Update SDimmers_levelUpdated.php
(SergeJey)
Dimmer level fix
https://github.com/sergejey/majordomo/commit/75485...
04.02.2023
Scenes refactoring
(SergeJey)
Scenes refactoring
Scenes code clean-up and refactoring
https://github.com/sergejey/majordomo/commit/2e582...
04.02.2023
Update patterns_edit.inc.php
(SergeJey)
Fix of error with DB strict mode enabled.
https://github.com/sergejey/majordomo/commit/f50ae...
24.01.2023
Widgets updates
(SergeJey)
Widgets updates
https://github.com/sergejey/majordomo/commit/8c49f...
22.01.2023
Scene widgets
(SergeJey)
Scene widgets
20.01.2023
Merge pull request #1068 from Alexandr-logrus/alpha
(SergeJey)
фикс счетчика пу
https://github.com/sergejey/majordomo/commit/10acc...
14.01.2023
Simple devices updates
(SergeJey)
26.12.2022
Merge pull request #1066 from SmoKE585/patch-10
(SergeJey)
Новый год пришел!
https://github.com/sergejey/majordomo/commit/527b9...
15.12.2022
Merge pull request #1065 from sergejey/revert-1064-patch-2
(SergeJey)
Revert "Подготовка к php8"
https://github.com/sergejey/majordomo/commit/8dae6...
14.12.2022
Merge pull request #1064 from eeak/patch-2
(SergeJey)
Подготовка к php8
https://github.com/sergejey/majordomo/commit/10ac4...
12.12.2022
Merge pull request #1061 from Anisan/patch-3
(SergeJey)
Websocket optimization
https://github.com/sergejey/majordomo/commit/37b32...
11.12.2022
Update loader.php
(SergeJey)
Update loader.php
Libraries preloader minor update
https://github.com/sergejey/majordomo/commit/7e585...
07.12.2022
end date for charts
(SergeJey)
end date for charts
Ability to select "end" date for charts.
https://github.com/sergejey/majordomo/commit/a68f8...
03.12.2022
Fixes
(SergeJey)
Fixes
26.11.2022
Merge pull request #1063 from ai91/feature/shoutboxfilter
(SergeJey)
Фильтр для истории событий в режиме site
https://github.com/sergejey/majordomo/commit/07815...
18.11.2022
Merge pull request #1059 from ai91/alpha
(SergeJey)
Отказоустойчивость для систем без модуля CONNECT
https://github.com/sergejey/majordomo/commit/52762...
22.10.2022
Line ending fix
(SergeJey)
Line ending fix
https://github.com/sergejey/majordomo/commit/9244a...
02.10.2022
Merge pull request #1058 from whitevast/patch-1
(SergeJey)
Openable Homebridge
https://github.com/sergejey/majordomo/commit/21e04...
11.09.2022
Updates
(SergeJey)
Updates
30.08.2022
Mode activation fix
(SergeJey)
Mode activation fix
https://github.com/sergejey/majordomo/commit/fe0ac...
29.08.2022
Updates
(SergeJey)
Updates
26.08.2022
Charts height fix
(SergeJey)
Charts height fix
https://github.com/sergejey/majordomo/commit/e4080...
Обсуждение (6) (0)
26.08.2022
Fixes
(SergeJey)
Fixes
26.08.2022
Merge pull request #1053 from Anisan/patch-2
(SergeJey)
Websocket: send data subscribed
https://github.com/sergejey/majordomo/commit/7821d...
25.08.2022
Update devices_search_admin.html
(SergeJey)
Show alternative titles in the list of devices in Control Panel
https://github.com/sergejey/majordomo/commit/bfe8a...
22.08.2022
Merge pull request #1052 from Anisan/patch-1
(SergeJey)
SAY: add id shouts in data for websocket
https://github.com/sergejey/majordomo/commit/a45b5...
22.08.2022
Minor updates
(SergeJey)
Minor updates
21.08.2022
Updates
(SergeJey)
Updates
18.08.2022
Update shouts_search.inc.php
(SergeJey)
Fix support of images in system chat
https://github.com/sergejey/majordomo/commit/e12cf...
17.08.2022
Updates
(SergeJey)
Updates
16.08.2022
Merge pull request #1051 from london89/patch-3
(SergeJey)
Update cycle.php
https://github.com/sergejey/majordomo/commit/f13ec...
15.08.2022
Panel icon fix
(SergeJey)
Panel icon fix
https://github.com/sergejey/majordomo/commit/b429d...
14.08.2022
Create panel_nav_top.tpl
(SergeJey)
https://github.com/sergejey/majordomo/commit/e028a...
14.08.2022
UI performance improvements
(SergeJey)
Обсуждение (2) (0)
13.08.2022
Scenes warning fix
(SergeJey)
Scenes warning fix
12.08.2022
(SergeJey)
Update to module installation/de-installation -- clean up of all files copied during install.
https://github.com/sergejey/majordomo/commit/9a06a...
08.08.2022
Update commands.class.php
(SergeJey)
Colors fix
https://github.com/sergejey/majordomo/commit/f6ca7...
08.08.2022
Merge pull request #1048 from kirush0280/patch-6
(SergeJey)
Update SThermostats.html
https://github.com/sergejey/majordomo/commit/a4b40...
08.08.2022
(SergeJey)
Color change fix
https://github.com/sergejey/majordomo/commit/0d46b...
08.08.2022
Menu code refactoring
(SergeJey)
https://github.com/sergejey/majordomo/commit/edf2e...
04.08.2022
Create SDevices_batteryLevelUpdated.php
(SergeJey)
https://github.com/sergejey/majordomo/commit/e1098...
04.08.2022
Update charts
(SergeJey)
Update charts
02.08.2022
Messages with images
(SergeJey)
Basic support for messages with images for "say" function (and events to other modules).
https://github.com/sergejey/majordomo/commit/67103...
01.08.2022
Updates
(SergeJey)
Updates
31.07.2022
Battery operated devices support
(SergeJey)
21.05.2022
Merge pull request #1035 from Anisan/patch-3
(SergeJey)
find data in modules
https://github.com/sergejey/majordomo/commit/c772b...
17.05.2022
Market fix
(SergeJey)
Market fix
https://github.com/sergejey/majordomo/commit/324a8...
10.05.2022
Optimization
(SergeJey)
Optimization
23.04.2022
Updates
(SergeJey)
Updates
15.04.2022
Merge pull request #1029 from london89/patch-2
(SergeJey)
Update panel.html
https://github.com/sergejey/majordomo/commit/03b80...
30.03.2022
Refactoring
(SergeJey)
Refactoring
Panel notifications refactoring
https://github.com/sergejey/majordomo/commit/5dd5a...
27.03.2022
Missing table error fix
(SergeJey)
https://github.com/sergejey/majordomo/commit/a541c...
17.02.2022
Merge pull request #1027 from london89/alpha
(SergeJey)
Изменения контроля циклов
https://github.com/sergejey/majordomo/commit/2a803...
10.02.2022
Update cycle.php
(SergeJey)
Update cycle.php
Revert changes
https://github.com/sergejey/majordomo/commit/01153...
09.02.2022
Merge pull request #1023 from SergMicar/alpha
(SergeJey)
Try to repait tables on MDM start if corrupted
https://github.com/sergejey/majordomo/commit/019ee...
05.02.2022
Updates
(SergeJey)
Updates
04.02.2022
Simple Devices update
(SergeJey)
02.02.2022
Merge pull request #1022 from tarasfrompir/patch-2
(SergeJey)
Update config.php.sample
https://github.com/sergejey/majordomo/commit/e4bae...
09.01.2022
Updates
(SergeJey)
Updates
29.12.2021
Merge pull request #1021 from london89/patch-1
(SergeJey)
https://github.com/sergejey/majordomo/commit/9bcb2...
10.12.2021
Updates
(SergeJey)
Updates
01.11.2021
Updates
(SergeJey)
Updates
16.10.2021
Merge pull request #1016 from SmoKE585/patch-9
(SergeJey)
Update ru.php
https://github.com/sergejey/majordomo/commit/5e288...
15.10.2021
Merge pull request #1012 from YuriiRadio/patch-4
(SergeJey)
dingdong fix
https://github.com/sergejey/majordomo/commit/51485...
05.10.2021
Merge pull request #1013 from SmoKE585/patch-8
(SergeJey)
Fix warning msg
https://github.com/sergejey/majordomo/commit/0c5c8...
01.10.2021
Mainenance change and link to module site
(SergeJey)
29.09.2021
Merge pull request #1011 from london89/alpha
(SergeJey)
Изменение контроля циклов
https://github.com/sergejey/majordomo/commit/60f8e...
24.09.2021
Update cycle.php
(SergeJey)
Update cycle.php
PHP notice fix
https://github.com/sergejey/majordomo/commit/c1584...
23.09.2021
Delete package.json
(SergeJey)
Delete package.json
https://github.com/sergejey/majordomo/commit/19693...
15.09.2021
Merge pull request #1007 from Anisan/patch-1
(SergeJey)
performance optimization for linkedobject
https://github.com/sergejey/majordomo/commit/4e41e...
06.09.2021
Merge pull request #1006 from tarasfrompir/patch-4
(SergeJey)
https://github.com/sergejey/majordomo/commit/f5e06...
03.09.2021
Merge pull request #1004 from tarasfrompir/patch-2
(SergeJey)
Update panel.class.php
https://github.com/sergejey/majordomo/commit/0bcb3...
30.08.2021
Merge pull request #1003 from tarasfrompir/patch-1
(SergeJey)
Update ua.php
https://github.com/sergejey/majordomo/commit/577bd...
30.08.2021
Merge pull request #1002 from SmoKE585/alpha
(SergeJey)
Уменьшено в 20 раз количество запросов к БД
https://github.com/sergejey/majordomo/commit/fd284...
24.08.2021
Control Panel part load fix
(SergeJey)
https://github.com/sergejey/majordomo/commit/d07f4...
24.08.2021
Merge pull request #999 from SmoKE585/alpha
(SergeJey)
Новый дизайн
https://github.com/sergejey/majordomo/commit/62777...
19.08.2021
Merge pull request #998 from SmoKE585/alpha
(SergeJey)
Фиксы темной темы
https://github.com/sergejey/majordomo/commit/b4a48...
14.08.2021
Merge pull request #996 from SmoKE585/alpha
(SergeJey)
Исправления темной темы
https://github.com/sergejey/majordomo/commit/734be...
10.08.2021
Merge pull request #995 from SmoKE585/alpha
(SergeJey)
Темная тема
https://github.com/sergejey/majordomo/commit/5fd3f...
09.08.2021
Merge pull request #994 from SmoKE585/alpha
(SergeJey)
Оповещения для модулей
https://github.com/sergejey/majordomo/commit/dc358...
06.08.2021
Merge pull request #993 from SmoKE585/alpha
(SergeJey)
Фикс кнопки в маркете
https://github.com/sergejey/majordomo/commit/2fc5f...
03.08.2021
Merge pull request #992 from SmoKE585/alpha
(SergeJey)
Много нового
https://github.com/sergejey/majordomo/commit/1600b...
23.07.2021
Merge pull request #990 from tarasfrompir/patch-1
(SergeJey)
Update cycle_states.php
https://github.com/sergejey/majordomo/commit/4c30b...
20.07.2021
Merge pull request #989 from tarasfrompir/patch-6
(SergeJey)
Update Server.php
https://github.com/sergejey/majordomo/commit/9e6d2...
20.07.2021
Merge pull request #985 from tarasfrompir/patch-3
(SergeJey)
https://github.com/sergejey/majordomo/commit/1973b...
17.07.2021
(SergeJey)
Templates processing fix
https://github.com/sergejey/majordomo/commit/1728d...
16.07.2021
(SergeJey)
Remove some warnings
https://github.com/sergejey/majordomo/commit/f7760...
14.07.2021
Update caching.class.php
(SergeJey)
Clearing the cache fix
https://github.com/sergejey/majordomo/commit/20352...
14.07.2021
Merge pull request #980 from tarasfrompir/patch-21
(SergeJey)
https://github.com/sergejey/majordomo/commit/f1796...
13.07.2021
Merge pull request #975 from tarasfrompir/patch-15
(SergeJey)
Update loader.php
https://github.com/sergejey/majordomo/commit/412b7...
09.07.2021
Update devices_edit.html
(SergeJey)
Fix of Simple Devices got archived by default
https://github.com/sergejey/majordomo/commit/968c8...
07.07.2021
Merge pull request #969 from london89/patch-4
(SergeJey)
Update devices.css
https://github.com/sergejey/majordomo/commit/ed41f...
21.06.2021
Merge pull request #967 from tarasfrompir/patch-9
(SergeJey)
Warning: Undefined array key "dynids" and 'part_load'
https://github.com/sergejey/majordomo/commit/9c06d...
21.06.2021
Merge pull request #966 from tarasfrompir/patch-8
(SergeJey)
Warning: Constant DEF_TYPE_OPTIONS already defined
https://github.com/sergejey/majordomo/commit/9f9b9...
21.06.2021
Merge pull request #965 from tarasfrompir/patch-7
(SergeJey)
Update python
https://github.com/sergejey/majordomo/commit/853f0...
11.06.2021
Minor updates
(SergeJey)
Minor updates
https://github.com/sergejey/majordomo/commit/f541b...
10.06.2021
Fixes
(SergeJey)
Fixes
08.06.2021
Merge pull request #930 from Anisan/alpha
(SergeJey)
Simple Devices: option no change level
https://github.com/sergejey/majordomo/commit/5a378...
08.06.2021
Merge pull request #964 from stell-hawk/alpha
(SergeJey)
Исправлена ошибка префикса в кеше
https://github.com/sergejey/majordomo/commit/6187d...
06.06.2021
Merge pull request #963 from Newz20/patch-2
(SergeJey)
https://github.com/sergejey/majordomo/commit/77e58...
28.05.2021
Updates
(SergeJey)
Updates
28.05.2021
Merge pull request #960 from stell-hawk/alpha
(SergeJey)
Кэш
https://github.com/sergejey/majordomo/commit/043ac...
26.05.2021
Merge pull request #961 from tarasfrompir/patch-6
(SergeJey)
Клас thread не нужен для мдм
https://github.com/sergejey/majordomo/commit/93491...
19.05.2021
Merge pull request #895 from YuriiRadio/patch-3
(SergeJey)
Fix SButtons_pressed.php
https://github.com/sergejey/majordomo/commit/4143c...
15.05.2021
Update scenes.class.php
(SergeJey)
Scenes fix
https://github.com/sergejey/majordomo/commit/98879...
15.05.2021
Simple Devices updates
(SergeJey)
11.05.2021
Merge pull request #955 from SmoKE585/alpha
(SergeJey)
Update market.html
https://github.com/sergejey/majordomo/commit/6f061...
09.05.2021
HomeBridge: CO2 sensor added
(SergeJey)
https://github.com/sergejey/majordomo/commit/cb554...
07.05.2021
Merge pull request #953 from SmoKE585/patch-4
(SergeJey)
Переносы строк в x-ray
https://github.com/sergejey/majordomo/commit/855ab...
20.04.2021
Merge pull request #952 from SmoKE585/alpha
(SergeJey)
Новые фишки дизайна
https://github.com/sergejey/majordomo/commit/4cba9...
19.04.2021
Merge pull request #951 from SmoKE585/alpha
(SergeJey)
Мелкие правки
https://github.com/sergejey/majordomo/commit/d520c...
18.04.2021
Merge pull request #950 from SmoKE585/alpha
(SergeJey)
Новый дизайн выбора свойств
https://github.com/sergejey/majordomo/commit/85890...
15.04.2021
Merge pull request #948 from SmoKE585/alpha
(SergeJey)
Резервный способ подсчета запросов
https://github.com/sergejey/majordomo/commit/1146c...
13.04.2021
Merge pull request #947 from SmoKE585/alpha
(SergeJey)
Изменен метод подсчета кол. запросов к БД
https://github.com/sergejey/majordomo/commit/04ee1...
13.04.2021
Merge pull request #946 from SmoKE585/alpha
(SergeJey)
Изменил селекторы свойств
https://github.com/sergejey/majordomo/commit/a8194...
07.04.2021
Merge pull request #945 from Aleks130699/patch-1
(SergeJey)
Update SOpenClose.html
https://github.com/sergejey/majordomo/commit/e168a...
31.03.2021
Merge pull request #942 from tarasfrompir/patch-24
(SergeJey)
https://github.com/sergejey/majordomo/commit/69304...
28.03.2021
(SergeJey)
28.03.2021
Merge pull request #940 from kvazimoda24/patch-6
(SergeJey)
Update panel.html
https://github.com/sergejey/majordomo/commit/ad109...
23.03.2021
Merge pull request #937 from london89/patch-3
(SergeJey)
Update SLeak_statusUpdated.php
https://github.com/sergejey/majordomo/commit/60290...
22.03.2021
Merge pull request #936 from kvazimoda24/patch-5
(SergeJey)
Update db_terminal.sql
https://github.com/sergejey/majordomo/commit/32275...
21.03.2021
New simple devices
(SergeJey)
New simple devices
21.03.2021
Templates fix
(SergeJey)
Templates fix
20.03.2021
Update SOpenable.html
(SergeJey)
19.03.2021
Merge pull request #935 from SmoKE585/alpha
(SergeJey)
Очередные фиксы меню
https://github.com/sergejey/majordomo/commit/13b3a...
19.03.2021
Merge pull request #934 from SmoKE585/patch-3
(SergeJey)
Фикс меню
https://github.com/sergejey/majordomo/commit/f6504...
18.03.2021
Merge pull request #933 from SmoKE585/alpha
(SergeJey)
Новые фиксы
https://github.com/sergejey/majordomo/commit/b0c70...
18.03.2021
Merge pull request #932 from SmoKE585/alpha
(SergeJey)
Мелкие фиксы дизайна
https://github.com/sergejey/majordomo/commit/2e39a...
17.03.2021
Openable: support partically open
(SergeJey)
17.03.2021
Startup maintenance update
(SergeJey)
16.03.2021
Merge pull request #928 from Alexandr-logrus/alpha
(SergeJey)
SCounters
https://github.com/sergejey/majordomo/commit/b49d0...
26.02.2021
Merge pull request #926 from SmoKE585/alpha
(SergeJey)
Выпилил лишнее и убрал утренний костыль
https://github.com/sergejey/majordomo/commit/dabd9...
26.02.2021
Merge pull request #924 from SmoKE585/patch-1
(SergeJey)
Временный костыль для показа классов
https://github.com/sergejey/majordomo/commit/ca863...
24.02.2021
Merge pull request #921 from SmoKE585/alpha
(SergeJey)
Исправление таймеров и проверки обновлений
https://github.com/sergejey/majordomo/commit/94396...
24.02.2021
Merge pull request #920 from SmoKE585/alpha
(SergeJey)
Alpha
https://github.com/sergejey/majordomo/commit/f83ab...
24.02.2021
Merge pull request #917 from alexanderznamensky/patch-3
(SergeJey)
https://github.com/sergejey/majordomo/commit/b3825...
22.02.2021
Merge pull request #915 from SmoKE585/alpha
(SergeJey)
Add description in class
https://github.com/sergejey/majordomo/commit/8189d...
20.02.2021
Merge pull request #914 from SmoKE585/alpha
(SergeJey)
Фикс мобильного вида
https://github.com/sergejey/majordomo/commit/4db6a...
19.02.2021
Merge pull request #913 from SmoKE585/alpha
(SergeJey)
Новый дизайн классы, объекты
https://github.com/sergejey/majordomo/commit/f7592...
16.02.2021
Merge pull request #912 from SmoKE585/alpha
(SergeJey)
Новый дизайн
https://github.com/sergejey/majordomo/commit/49697...
16.02.2021
Merge pull request #877 from Gastello007/patch-17
(SergeJey)
Update mjdm.py
https://github.com/sergejey/majordomo/commit/4599a...
15.02.2021
Merge pull request #910 from SmoKE585/alpha
(SergeJey)
Новый дизайн свойств
https://github.com/sergejey/majordomo/commit/72fa8...
14.02.2021
Merge pull request #909 from SmoKE585/alpha
(SergeJey)
Исправления консоли, меню, поиск
https://github.com/sergejey/majordomo/commit/bc228...
14.02.2021
Merge pull request #908 from SmoKE585/alpha
(SergeJey)
Фиксы для консоли
https://github.com/sergejey/majordomo/commit/4b57b...
14.02.2021
Merge pull request #907 from SmoKE585/alpha
(SergeJey)
Фиксы
https://github.com/sergejey/majordomo/commit/de08b...
14.02.2021
Merge pull request #906 from SmoKE585/alpha
(SergeJey)
Изменения поиска
https://github.com/sergejey/majordomo/commit/7a46a...
14.02.2021
Merge pull request #905 from SmoKE585/alpha
(SergeJey)
Новый дизайн
https://github.com/sergejey/majordomo/commit/4eac4...
13.02.2021
Simple devices: templates added
(SergeJey)
12.02.2021
Merge pull request #903 from SmoKE585/alpha
(SergeJey)
Фиксы
https://github.com/sergejey/majordomo/commit/d953c...
12.02.2021
Merge pull request #902 from SmoKE585/alpha
(SergeJey)
Красивый вывод для модуля Сценарии
https://github.com/sergejey/majordomo/commit/1599a...
11.02.2021
Merge pull request #901 from SmoKE585/alpha
(SergeJey)
Новая версия таймеров ПУ
https://github.com/sergejey/majordomo/commit/64e0f...
11.02.2021
Merge pull request #900 from tarasfrompir/patch-19
(SergeJey)
Update ua.php
https://github.com/sergejey/majordomo/commit/306db...
10.02.2021
Merge pull request #899 from SmoKE585/alpha
(SergeJey)
LANG файлы
https://github.com/sergejey/majordomo/commit/25542...
10.02.2021
Merge pull request #898 from SmoKE585/alpha
(SergeJey)
Alpha
https://github.com/sergejey/majordomo/commit/5ce40...
09.02.2021
Merge pull request #896 from tarasfrompir/patch-18
(SergeJey)
Update devices.css
https://github.com/sergejey/majordomo/commit/bd0eb...
05.02.2021
Optimizing
(SergeJey)
Optimizing
Обсуждение (1) (2)
04.02.2021
Merge pull request #893 from YuriiRadio/patch-2
(SergeJey)
Update ua.php
https://github.com/sergejey/majordomo/commit/f1fee...
02.02.2021
Optimizing and minor changes
(SergeJey)
29.01.2021
Merge pull request #888 from london89/alpha
(SergeJey)
homebridge fix and adding
https://github.com/sergejey/majordomo/commit/9db45...
28.01.2021
Merge pull request #887 from london89/patch-6
(SergeJey)
Update homebridgeSync.inc.php
https://github.com/sergejey/majordomo/commit/6245f...
18.01.2021
Merge pull request #883 from alexanderznamensky/patch-1
(SergeJey)
Update ru.php
https://github.com/sergejey/majordomo/commit/bd433...
Обсуждение (0) (4)
29.12.2020
Merge pull request #878 from tarasfrompir/patch-15
(SergeJey)
https://github.com/sergejey/majordomo/commit/9945a...
28.12.2020
(SergeJey)
Connect cycle hang fix
https://github.com/sergejey/majordomo/commit/8bba2...
27.12.2020
Updates
(SergeJey)
Updates
25.12.2020
Merge pull request #881 from IvanSHatrykin/alpha
(SergeJey)
Update SSmoke_statusUpdated.php
https://github.com/sergejey/majordomo/commit/29e8b...
24.12.2020
Merge pull request #880 from london89/patch-5
(SergeJey)
https://github.com/sergejey/majordomo/commit/edb4a...
16.12.2020
Minor updates
(SergeJey)
Minor updates
10.12.2020
(SergeJey)
10.12.2020
Merge pull request #876 from Gastello007/patch-16
(SergeJey)
Update general.py
https://github.com/sergejey/majordomo/commit/dd025...
07.12.2020
Merge pull request #875 from YuriiRadio/patch-10
(SergeJey)
https://github.com/sergejey/majordomo/commit/15a22...
30.11.2020
Merge pull request #872 from SmoKE585/alpha
(SergeJey)
Фикс фикса =) Накосячил
https://github.com/sergejey/majordomo/commit/adcd8...
30.11.2020
Merge pull request #866 from tarasfrompir/patch-14
(SergeJey)
Update ua.php
https://github.com/sergejey/majordomo/commit/85e10...
30.11.2020
Merge pull request #864 from tarasfrompir/patch-13
(SergeJey)
Update ua.php
https://github.com/sergejey/majordomo/commit/0d88a...
30.11.2020
Merge pull request #863 from SmoKE585/alpha
(SergeJey)
LANG файлы для маркета
https://github.com/sergejey/majordomo/commit/d61c4...
28.11.2020
Merge pull request #862 from SmoKE585/alpha
(SergeJey)
https://github.com/sergejey/majordomo/commit/ba3c9...
26.11.2020
Optimizing
(SergeJey)
Optimizing
New config option: LOWER_BACKGROUND_PROCESSES
log4php library removed
https://github.com/sergejey/majordomo/commit/ae4e9...
26.11.2020
Merge pull request #861 from Gastello007/patch-13
(SergeJey)
Patch 13
https://github.com/sergejey/majordomo/commit/3a533...
24.11.2020
Merge pull request #857 from tarasfrompir/patch-12
(SergeJey)
Откат изменений
https://github.com/sergejey/majordomo/commit/84862...
23.11.2020
Merge pull request #856 from tarasfrompir/patch-11
(SergeJey)
https://github.com/sergejey/majordomo/commit/f1214...
23.11.2020
Merge pull request #855 from tarasfrompir/patch-10
(SergeJey)
https://github.com/sergejey/majordomo/commit/535a7...
20.11.2020
Merge pull request #854 from SmoKE585/alpha
(SergeJey)
Откат дизайн назад
https://github.com/sergejey/majordomo/commit/9b4c0...
19.11.2020
Merge pull request #852 from tarasfrompir/patch-9
(SergeJey)
Update ua.php
https://github.com/sergejey/majordomo/commit/2745a...
18.11.2020
Merge pull request #784 from rems117/pinghosts_edit
(SergeJey)
pinghosts edit
https://github.com/sergejey/majordomo/commit/86270...
18.11.2020
Merge pull request #851 from tarasfrompir/patch-8
(SergeJey)
edit addClass function and add some function
https://github.com/sergejey/majordomo/commit/0e824...
17.11.2020
Merge pull request #838 from tarasfrompir/patch-1
(SergeJey)
Delete Time To live from cached tables
https://github.com/sergejey/majordomo/commit/213a6...
16.11.2020
Merge pull request #846 from solalex1/alpha
(SergeJey)
https://github.com/sergejey/majordomo/commit/18799...
15.11.2020
Merge pull request #843 from SmoKE585/alpha
(SergeJey)
Новые функции дизайна!
https://github.com/sergejey/majordomo/commit/f128d...
14.11.2020
Merge pull request #842 from SmoKE585/alpha
(SergeJey)
Обновление дизайна
https://github.com/sergejey/majordomo/commit/46eb4...
13.11.2020
Merge pull request #841 from SmoKE585/alpha
(SergeJey)
Wellcome New Design!
https://github.com/sergejey/majordomo/commit/00411...
01.11.2020
Merge pull request #837 from SmoKE585/alpha
(SergeJey)
!!!Срочные!!! фиксы редактора кода
https://github.com/sergejey/majordomo/commit/4d6ff...
30.10.2020
Simple Devices
(SergeJey)
Simple Devices
Optmize of http requests for devices
https://github.com/sergejey/majordomo/commit/630d1...
26.10.2020
Merge pull request #834 from tarasfrompir/patch-22
(SergeJey)
https://github.com/sergejey/majordomo/commit/ac64e...
21.10.2020
Merge pull request #828 from tarasfrompir/patch-19
(SergeJey)
Update Python function
https://github.com/sergejey/majordomo/commit/8073d...
19.10.2020
Merge pull request #824 from tarasfrompir/patch-15
(SergeJey)
Убрал ненужное свойство - для дальнейшей оптимизации
https://github.com/sergejey/majordomo/commit/3d904...
18.10.2020
Merge pull request #823 from Gastello007/patch-4
(SergeJey)
Update mjdm.py
https://github.com/sergejey/majordomo/commit/ac6c1...
15.10.2020
Merge pull request #822 from Gastello007/patch-3
(SergeJey)
Update mjdm.py
https://github.com/sergejey/majordomo/commit/3de4f...
15.10.2020
Merge pull request #821 from Gastello007/patch-2
(SergeJey)
Update mjdm.py
https://github.com/sergejey/majordomo/commit/834de...
15.10.2020
Update mjdm.py
(SergeJey)
Update mjdm.py
Python fix
https://github.com/sergejey/majordomo/commit/4fdd3...
14.10.2020
Update mjdm.py
(SergeJey)
Update mjdm.py
Python callMethod parameters fix
https://github.com/sergejey/majordomo/commit/fc686...
14.10.2020
Merge pull request #818 from tarasfrompir/patch-13
(SergeJey)
Немного пропустили ошибку
https://github.com/sergejey/majordomo/commit/08b0f...
Обсуждение (1) (1)
13.10.2020
Merge pull request #809 from tarasfrompir/patch-11
(SergeJey)
Update copyTree function
https://github.com/sergejey/majordomo/commit/7452b...
12.10.2020
Merge pull request #817 from london89/patch-4
(SergeJey)
https://github.com/sergejey/majordomo/commit/445e0...
12.10.2020
Merge pull request #816 from SmoKE585/alpha
(SergeJey)
Исправления для редактора
https://github.com/sergejey/majordomo/commit/697f3...
09.10.2020
Merge pull request #815 from SmoKE585/alpha
(SergeJey)
Фиксы для редактора кода
https://github.com/sergejey/majordomo/commit/e6037...
04.10.2020
(SergeJey)
23.09.2020
Merge pull request #799 from tarasfrompir/patch-1
(SergeJey)
Исправление отображения количества строк в ХРАЙ
https://github.com/sergejey/majordomo/commit/eefc9...
23.09.2020
Merge pull request #798 from Anisan/patch-5
(SergeJey)
fix SOpenClose_statusUpdated.php
https://github.com/sergejey/majordomo/commit/71d9d...
22.09.2020
(SergeJey)
21.09.2020
Merge pull request #797 from tarasfrompir/patch-2
(SergeJey)
Update syncfiles.class.php
https://github.com/sergejey/majordomo/commit/61346...
21.09.2020
Merge pull request #796 from tarasfrompir/patch-1
(SergeJey)
https://github.com/sergejey/majordomo/commit/3bcf6...
20.09.2020
Updates
(SergeJey)
Updates
15.09.2020
Merge pull request #795 from tarasfrompir/patch-8
(SergeJey)
Deprecated: Array and string offset access syntax with curly braces i…
https://github.com/sergejey/majordomo/commit/9c43a...
11.09.2020
Merge pull request #790 from tarasfrompir/patch-3
(SergeJey)
https://github.com/sergejey/majordomo/commit/5b4e1...
10.09.2020
Merge pull request #789 from tarasfrompir/patch-2
(SergeJey)
Введен флаг для контроля запуска Сафе метода....
https://github.com/sergejey/majordomo/commit/aa0e4...
08.09.2020
Merge pull request #786 from tarasfrompir/patch-1
(SergeJey)
Добавлена функция получения списка файлов в директории
https://github.com/sergejey/majordomo/commit/c609c...
07.09.2020
Updates
(SergeJey)
Updates
05.09.2020
Merge pull request #785 from tarasfrompir/alpha
(SergeJey)
Перенесены некоторые функции из класса в класс
https://github.com/sergejey/majordomo/commit/0bb4c...
23.08.2020
Merge pull request #779 from Anisan/patch-4
(SergeJey)
API: view system_device
https://github.com/sergejey/majordomo/commit/194fc...
05.08.2020
Merge pull request #778 from london89/patch-3
(SergeJey)
https://github.com/sergejey/majordomo/commit/5d9b0...
05.08.2020
Merge pull request #777 from london89/patch-2
(SergeJey)
https://github.com/sergejey/majordomo/commit/d0298...
04.08.2020
Merge pull request #775 from tarasfrompir/patch-9
(SergeJey)
Update index.php
https://github.com/sergejey/majordomo/commit/73167...
20.07.2020
(SergeJey)
Simple devices: support of Air Conditioners added
https://github.com/sergejey/majordomo/commit/140b1...
15.07.2020
Merge pull request #773 from tarasfrompir/patch-7
(SergeJey)
Update .htaccess
https://github.com/sergejey/majordomo/commit/2299f...
09.07.2020
Merge pull request #772 from nick7zmail/master
(SergeJey)
fix api and db
https://github.com/sergejey/majordomo/commit/ea8ed...
08.07.2020
Merge pull request #771 from Alexandr-logrus/alpha
(SergeJey)
Alpha
https://github.com/sergejey/majordomo/commit/8b4d4...
27.06.2020
Updates
(SergeJey)
Updates
Обсуждение (1) (1)
22.06.2020
Merge pull request #765 from rems117/pinghosts_fixing_bug
(SergeJey)
Pinghosts fixing bug
https://github.com/sergejey/majordomo/commit/4fd50...
14.06.2020
Merge pull request #764 from SmoKE585/alpha
(SergeJey)
Фикс: Редактор кода
https://github.com/sergejey/majordomo/commit/692ac...
12.06.2020
Merge pull request #763 from SmoKE585/alpha
(SergeJey)
Исправление ошибок редактора кода
https://github.com/sergejey/majordomo/commit/36cc9...
11.06.2020
Merge pull request #762 from SmoKE585/alpha
(SergeJey)
Новые функции редактора кода
https://github.com/sergejey/majordomo/commit/207b9...
08.06.2020
Merge pull request #761 from SmoKE585/alpha
(SergeJey)
Пересобран редактор кода + фикс дизайна
https://github.com/sergejey/majordomo/commit/9dca4...
05.06.2020
Merge pull request #758 from tarasfrompir/patch-1
(SergeJey)
Добавлено розграничение прав доступа к терминалам
https://github.com/sergejey/majordomo/commit/0ea6c...
03.06.2020
Merge pull request #757 from SmoKE585/alpha
(SergeJey)
Редактор кода с подсветкой ошибок
https://github.com/sergejey/majordomo/commit/97f41...
02.06.2020
Update MajordomoApplication.php
(SergeJey)
Websockets fix
https://github.com/sergejey/majordomo/commit/2c333...
02.06.2020
Update cycle.php
(SergeJey)
Update cycle.php
Cycles monitoring fix
https://github.com/sergejey/majordomo/commit/e3679...
01.06.2020
Merge pull request #747 from london89/alpha
(SergeJey)
Отслеживание циклов
https://github.com/sergejey/majordomo/commit/0dd0b...
Обсуждение (1) (0)
26.05.2020
Merge pull request #744 from tarasfrompir/patch-5
(SergeJey)
https://github.com/sergejey/majordomo/commit/3cbe9...
25.05.2020
Merge pull request #743 from tarasfrompir/patch-4
(SergeJey)
Увеличено время сохранения кеша до недели
https://github.com/sergejey/majordomo/commit/fbb6e...
20.05.2020
Merge pull request #740 from tarasfrompir/patch-3
(SergeJey)
https://github.com/sergejey/majordomo/commit/01edb...
17.05.2020
Update phpMQTT.php
(SergeJey)
Update phpMQTT.php
MQTT library update
https://github.com/sergejey/majordomo/commit/11535...
17.05.2020
Merge pull request #739 from tarasfrompir/patch-2
(SergeJey)
подключено команду открой закрой к ПУ класс openable
https://github.com/sergejey/majordomo/commit/19f87...
15.05.2020
Merge pull request #738 from sergejey/revert-736-patch-1
(SergeJey)
Revert "Добавлен выбор использования КЕШ в памяти"
https://github.com/sergejey/majordomo/commit/e09b1...
15.05.2020
Merge pull request #736 from tarasfrompir/patch-1
(SergeJey)
https://github.com/sergejey/majordomo/commit/3f1e9...
14.05.2020
Merge pull request #737 from Anisan/patch-3
(SergeJey)
Simple devices: add config_type readonly, rgb
https://github.com/sergejey/majordomo/commit/ff070...
Обсуждение (1) (0)
30.04.2020
Merge pull request #733 from tarasfrompir/patch-11
(SergeJey)
Update cycle_execs.php
https://github.com/sergejey/majordomo/commit/2753a...
30.04.2020
Merge pull request #731 from tarasfrompir/patch-10
(SergeJey)
https://github.com/sergejey/majordomo/commit/d82a2...
27.04.2020
Merge pull request #730 from tarasfrompir/patch-9
(SergeJey)
https://github.com/sergejey/majordomo/commit/3355c...
20.04.2020
Merge pull request #728 from london89/alpha
(SergeJey)
SETTINGS_SITE_TITLE fix
https://github.com/sergejey/majordomo/commit/2bf98...
18.04.2020
Leak/Smoke room title fix
(SergeJey)
15.04.2020
Merge pull request #727 from tarasfrompir/patch-7
(SergeJey)
Создано поле проверки пароля
https://github.com/sergejey/majordomo/commit/4ad48...
14.04.2020
Merge pull request #725 from tarasfrompir/patch-5
(SergeJey)
Удален из СистемСтайтс цикл Вебварс
https://github.com/sergejey/majordomo/commit/c68e0...
14.04.2020
Merge pull request #724 from tarasfrompir/patch-3
(SergeJey)
https://github.com/sergejey/majordomo/commit/80a80...
13.04.2020
Merge pull request #723 from tarasfrompir/patch-2
(SergeJey)
https://github.com/sergejey/majordomo/commit/d6dfa...
09.04.2020
Merge pull request #722 from tarasfrompir/patch-1
(SergeJey)
https://github.com/sergejey/majordomo/commit/95bef...
08.04.2020
Merge pull request #721 from Zaitsev-ap/patch-1
(SergeJey)
Update common.class.php в части runScriptSafe
https://github.com/sergejey/majordomo/commit/7f9fb...
07.04.2020
Merge pull request #719 from tarasfrompir/patch-41
(SergeJey)
Update terminals.class.php
https://github.com/sergejey/majordomo/commit/baa2e...
31.03.2020
Merge pull request #718 from tarasfrompir/patch-40
(SergeJey)
update callMethodSafe and seek CrossLinked methods
https://github.com/sergejey/majordomo/commit/54546...
28.03.2020
Updates
(SergeJey)
Updates
  • Keep menu state on reload (Control Panel) - fixed
  • Actions Log -- clear all button added
  • Simple Devices: app view groups separator fixed
  • Simple Devices: alive timeout can be negative (to avoid offline state)
  • Simple Devices: keepAlive method fix
  • Simple Devices: Dimmers now works with Room Activity update
  • Simple Devices: Buttons now works with Room Activity update
  • System: LoadFile warning fixed when file size = 0
    https://github.com/sergejey/majordomo/commit/d52f1...
25.03.2020
Merge pull request #717 from artm04/patch-2
(SergeJey)
Replace the params dict with the kwargs
https://github.com/sergejey/majordomo/commit/33f90...
24.03.2020
Merge pull request #714 from artm04/patch-1
(SergeJey)
Fix urllib.urlencode import for Python 3
https://github.com/sergejey/majordomo/commit/9a48b...
16.03.2020
Merge pull request #710 from kvazimoda24/patch-4
(SergeJey)
Исправление работы из подкаталога
https://github.com/sergejey/majordomo/commit/d9265...
10.03.2020
Merge pull request #706 from tarasfrompir/patch-34
(SergeJey)
Ошибка сохранения пароля
https://github.com/sergejey/majordomo/commit/744ba...
09.03.2020
Merge pull request #705 from ai91/alpha
(SergeJey)
Редактор простых устройств: не менять класс связанного объекта если он является подклассом выбранного типа
https://github.com/sergejey/majordomo/commit/3d2d1...
06.03.2020
Merge pull request #704 from tarasfrompir/patch-33
(SergeJey)
Изменение времени таймаута
https://github.com/sergejey/majordomo/commit/5fc21...
05.03.2020
Merge pull request #702 from tarasfrompir/patch-32
(SergeJey)
https://github.com/sergejey/majordomo/commit/14a73...
01.03.2020
Merge pull request #701 from tarasfrompir/patch-31
(SergeJey)
https://github.com/sergejey/majordomo/commit/2e4e1...
26.02.2020
Merge pull request #697 from tarasfrompir/patch-27
(SergeJey)
Сокрытие имени пользователя в ссылке на главную страницу
https://github.com/sergejey/majordomo/commit/0ac09...
21.02.2020
Merge pull request #695 from tarasfrompir/patch-26
(SergeJey)
Update hooks.inc.php
https://github.com/sergejey/majordomo/commit/cad6f...
20.02.2020
Merge pull request #692 from tarasfrompir/patch-23
(SergeJey)
Update action_usual.html
https://github.com/sergejey/majordomo/commit/219fa...
17.02.2020
Merge pull request #691 from london89/alpha
(SergeJey)
fix write_error url
https://github.com/sergejey/majordomo/commit/3d190...
16.02.2020
Merge pull request #689 from Alexandr-logrus/alpha
(SergeJey)
small fix
https://github.com/sergejey/majordomo/commit/8ea6e...
14.02.2020
Merge pull request #688 from Alexandr-logrus/alpha
(SergeJey)
Update SRGB.html
https://github.com/sergejey/majordomo/commit/88195...
14.02.2020
Update objects.class.php
(SergeJey)
callapi function fix
https://github.com/sergejey/majordomo/commit/16c52...
11.02.2020
Merge pull request #684 from tarasfrompir/patch-22
(SergeJey)
Обязательная проверка наличия логина и пароля
https://github.com/sergejey/majordomo/commit/39b02...
11.02.2020
Updates
(SergeJey)
Updates
11.02.2020
Fixes
(SergeJey)
Fixes
07.02.2020
Minor fixes
(SergeJey)
Minor fixes
07.02.2020
Merge pull request #682 from Alexandr-logrus/alpha
(SergeJey)
https://github.com/sergejey/majordomo/commit/b3dd6...
05.02.2020
Merge pull request #680 from tarasfrompir/patch-19
(SergeJey)
Убран дубляж - $session->data['logged_user'] все перенесено в $session->data['SITE_USER_ID']
https://github.com/sergejey/majordomo/commit/4f0a4...
05.02.2020
Merge pull request #678 from tarasfrompir/patch-16
(SergeJey)
Update panel.html
https://github.com/sergejey/majordomo/commit/0462d...
03.02.2020
Merge branch 'alpha' of https://github.com/sergejey/majordomo into alpha
(SergeJey)
https://github.com/sergejey/majordomo/commit/100dd...
30.01.2020
Merge pull request #673 from kvazimoda24/patch-1
(SergeJey)
Скриншоты с камеры при работе из подкаталога.
https://github.com/sergejey/majordomo/commit/817e2...
Обсуждение (1) (0)
30.01.2020
Merge pull request #670 from Aleks130699/patch-2
(SergeJey)
https://github.com/sergejey/majordomo/commit/08932...
29.01.2020
Optimizing
(SergeJey)
Optimizing
https://github.com/sergejey/majordomo/commit/4897d...
29.01.2020
Fixes
(SergeJey)
Fixes
Minor tweaks
https://github.com/sergejey/majordomo/commit/2d52b...
28.01.2020
Update mysqli.class.php
(SergeJey)
Error processing updated
https://github.com/sergejey/majordomo/commit/08385...
28.01.2020
Merge pull request #668 from tarasfrompir/patch-15
(SergeJey)
Добавлено местоположение терминала
https://github.com/sergejey/majordomo/commit/58dd2...
27.01.2020
(SergeJey)
API fix
https://github.com/sergejey/majordomo/commit/d1998...
27.01.2020
Merge pull request #666 from kvazimoda24/alpha
(SergeJey)
Исправление работы системы из подкаталога
https://github.com/sergejey/majordomo/commit/1b96c...
27.01.2020
Merge pull request #665 from tarasfrompir/patch-13
(SergeJey)
Использование местопоположения устройства
https://github.com/sergejey/majordomo/commit/27110...
26.01.2020
Merge pull request #660 from tarasfrompir/patch-10
(SergeJey)
https://github.com/sergejey/majordomo/commit/f0db0...
Обсуждение (1) (0)
24.01.2020
New feature: auto-update
(SergeJey)
23.01.2020
Merge pull request #659 from palacex/upstream_alpha
(SergeJey)
Upstream alpha
https://github.com/sergejey/majordomo/commit/4f616...
21.01.2020
Merge pull request #653 from tarasfrompir/patch-8
(SergeJey)
Исправление передачи длительности команды через консоль
https://github.com/sergejey/majordomo/commit/3f87b...
20.01.2020
Updates
(SergeJey)
Updates
20.01.2020
Merge pull request #650 from tarasfrompir/patch-6
(SergeJey)
Исправление выдачи терминала с которого пришла команда
https://github.com/sergejey/majordomo/commit/b88e8...
17.01.2020
Simple Devices fixes
(SergeJey)
17.01.2020
Updates
(SergeJey)
Updates
16.01.2020
Simple Devices homekit fixes
(SergeJey)
15.01.2020
Simple Devices: dimming fix
(SergeJey)
Minor fix for dimmers
https://github.com/sergejey/majordomo/commit/5e773...
13.01.2020
Update api.php
(SergeJey)
Update api.php
Minor api fix
https://github.com/sergejey/majordomo/commit/51c21...
13.01.2020
Merge pull request #647 from xor2016/alpha
(SergeJey)
Update freeboard.widgets.js
https://github.com/sergejey/majordomo/commit/9d414...
12.01.2020
Linked modules fix
(SergeJey)
Linked modules fix
Fixing call for linked modules with property update
https://github.com/sergejey/majordomo/commit/59133...
07.01.2020
Merge pull request #645 from Alexandr-logrus/alpha
(SergeJey)
Alpha
https://github.com/sergejey/majordomo/commit/020ca...
05.01.2020
Cross-link warning fix
(SergeJey)
https://github.com/sergejey/majordomo/commit/742b6...
04.01.2020
Simple devices fix
(SergeJey)
Simple devices fix
Simple Devices: power sensor fix
https://github.com/sergejey/majordomo/commit/d2309...
02.01.2020
Fixes
(SergeJey)
Fixes
26.12.2019
Updates
(SergeJey)
Updates
20.12.2019
Updates
(SergeJey)
Updates
06.12.2019
Merge pull request #639 from tarasfrompir/patch-4
(SergeJey)
https://github.com/sergejey/majordomo/commit/41c26...
05.12.2019
Merge pull request #638 from tarasfrompir/patch-3
(SergeJey)
Update php_check.class.php
https://github.com/sergejey/majordomo/commit/0e780...
05.12.2019
Merge pull request #636 from tarasfrompir/patch-6
(SergeJey)
https://github.com/sergejey/majordomo/commit/d0251...
29.11.2019
Merge pull request #634 from Anisan/alpha
(SergeJey)
API: fix find module
https://github.com/sergejey/majordomo/commit/3bcf4...
26.11.2019
(SergeJey)
25.11.2019
(SergeJey)
20.11.2019
Update python.inc.php
(SergeJey)
Python integration fix
https://github.com/sergejey/majordomo/commit/e184e...
20.11.2019
Minor updates
(SergeJey)
Minor updates
20.11.2019
Python support minor fix
(SergeJey)
Python syntax fix
https://github.com/sergejey/majordomo/commit/a5193...
20.11.2019
Python support
(SergeJey)
Python support
Basic support of Python code. Details at https://mjdm.ru/forum/viewtopic.php?f=4&t=6831
https://github.com/sergejey/majordomo/commit/243e1...
Обсуждение (5) (2)
14.11.2019
Updates
(SergeJey)
Updates
  • General settings: ability to set debmes logs path
  • System: database-saving script now stores main data / history data separtely
  • General settings: ability to set time period for saving database to disk (main data / history data separtely) -- useful for SD-card write optimizing
  • Simple Devices: Quick Edit mode to manage all devices/rooms at one page (useful for integrators and quick setup)
    https://github.com/sergejey/majordomo/commit/78fb4...
12.11.2019
Updates
(SergeJey)
Updates
06.11.2019
Update html.class.php
(SergeJey)
Component HTML fix
https://github.com/sergejey/majordomo/commit/89ccc...
06.11.2019
Plans html processing
(SergeJey)
05.11.2019
Simple devices: single device code
(SergeJey)
04.11.2019
Minor changes
(SergeJey)
Minor changes
Minor simple devices styling changes.
https://github.com/sergejey/majordomo/commit/7ea37...
15.10.2019
Scenes/Styles updates
(SergeJey)
Updates to the process of adding devices to the scene.
https://github.com/sergejey/majordomo/commit/c760a...
15.10.2019
Multiple classview templates
(SergeJey)
06.10.2019
Plans fixes
(SergeJey)
Plans fixes
03.10.2019
Updates
(SergeJey)
Updates
  • 3rd party: Fancybox lib update
  • API: not passing params to module api() fixed
  • db_terminal -- minor error in data fixed
  • Settings: ability to disable DebMes logging
  • Scenes: bug with elements linked to device fixed
  • Simple Devices: openable status minor bug fixed
    https://github.com/sergejey/majordomo/commit/5d78f...
30.09.2019
Properties validation rules
(SergeJey)
https://mjdm.ru/Hints/validationtype?skin=hint
https://github.com/sergejey/majordomo/commit/334c8...
Обсуждение (1) (1)
30.09.2019
CONNECT update
(SergeJey)
CONNECT update
Remote access now works correct with big forms (POST requests)
https://github.com/sergejey/majordomo/commit/8cab8...
25.09.2019
Update cycle.php
(SergeJey)
Update cycle.php
Auto-restart fix
https://github.com/sergejey/majordomo/commit/6998b...
Обсуждение (5) (1)
25.09.2019
Update connect.class.php
(SergeJey)
24.09.2019
Updates
(SergeJey)
Updates
Обсуждение (2) (0)
23.09.2019
Blockly fix
(SergeJey)
Blockly fix
23.09.2019
Minor fixes
(SergeJey)
Minor fixes
https://github.com/sergejey/majordomo/commit/9adc7...
23.09.2019
Merge pull request #629 from Vovix73/Vovix73-patch-1
(SergeJey)
Vovix73 patch 1
https://github.com/sergejey/majordomo/commit/375df...
Обсуждение (1) (0)
22.09.2019
Merge pull request #628 from zimur/fix-callMethodSafe
(SergeJey)
Fix callMethodSafe
https://github.com/sergejey/majordomo/commit/e050f...
16.09.2019
Updates
(SergeJey)
Updates
Обсуждение (1) (0)
11.09.2019
Patters update
(SergeJey)
Patters update
11.09.2019
(SergeJey)
https://github.com/sergejey/majordomo/commit/f39eb...
11.09.2019
Merge pull request #623 from london89/patch-2
(SergeJey)
Update api.php
https://github.com/sergejey/majordomo/commit/e680b...
10.09.2019
Minor updates
(SergeJey)
Minor updates
09.09.2019
Merge pull request #620 from tarasfrompir/patch-4
(SergeJey)
Patch 4
https://github.com/sergejey/majordomo/commit/ab883...
09.09.2019
(SergeJey)
https://github.com/sergejey/majordomo/commit/385dc...
06.09.2019
Merge pull request #619 from directman66/patch-21
(SergeJey)
Update settings_search.inc.php
https://github.com/sergejey/majordomo/commit/ce4f7...
04.09.2019
Updates
(SergeJey)
Updates
30.08.2019
Merge pull request #618 from directman66/patch-20
(SergeJey)
https://github.com/sergejey/majordomo/commit/96dd6...
29.08.2019
Updates
(SergeJey)
Updates
27.08.2019
Merge pull request #617 from tarasfrompir/patch-3
(SergeJey)
get volume to main terminal
https://github.com/sergejey/majordomo/commit/2460e...
27.08.2019
Blockly update
(SergeJey)
Blockly update
Google Blockly update
https://github.com/sergejey/majordomo/commit/63ec4...
27.08.2019
Minor update
(SergeJey)
Minor update
26.08.2019
Sensors update
(SergeJey)
Sensors update
22.08.2019
Merge pull request #604 from tarasfrompir/patch-6
(SergeJey)
https://github.com/sergejey/majordomo/commit/910c8...
20.08.2019
Merge pull request #601 from tarasfrompir/patch-4
(SergeJey)
add function setTerminalMML
https://github.com/sergejey/majordomo/commit/5a0f4...
20.08.2019
Merge pull request #602 from tarasfrompir/patch-5
(SergeJey)
Update ua.php
https://github.com/sergejey/majordomo/commit/1a74a...
16.08.2019
Merge pull request #599 from tarasfrompir/patch-3
(SergeJey)
https://github.com/sergejey/majordomo/commit/5317c...
16.08.2019
Merge pull request #598 from tarasfrompir/patch-2
(SergeJey)
Добавлена функция получения данных о медиа файле
https://github.com/sergejey/majordomo/commit/62a09...
15.08.2019
Merge pull request #596 from tarasfrompir/patch-7
(SergeJey)
add setPlayerVolume function
https://github.com/sergejey/majordomo/commit/135c1...
15.08.2019
Merge pull request #595 from directman66/patch-10
(SergeJey)
https://github.com/sergejey/majordomo/commit/8ea3b...
14.08.2019
Updates
(SergeJey)
Updates
12.08.2019
Updates
(SergeJey)
Updates
02.08.2019
Blockly fix
(SergeJey)
Blockly fix
https://github.com/sergejey/majordomo/commit/8a0cf...
02.08.2019
Control Panel fix
(SergeJey)
Control Panel fix
01.08.2019
(SergeJey)
stopMedia function
https://github.com/sergejey/majordomo/commit/e9bfb...
31.07.2019
Merge pull request #587 from deg026/patch-1
(SergeJey)
Autoresize
https://github.com/sergejey/majordomo/commit/96a0d...
23.07.2019
Merge pull request #589 from tarasfrompir/patch-2
(SergeJey)
добавлена функция проверки наличия файла
https://github.com/sergejey/majordomo/commit/9c4c5...
14.07.2019
Merge pull request #585 from Alexandr-logrus/alpha
(SergeJey)
https://github.com/sergejey/majordomo/commit/ae2f1...
10.07.2019
API POST method
(SergeJey)
API POST method
https://github.com/sergejey/majordomo/commit/3bd89...
09.07.2019
Update api.php
(SergeJey)
Update api.php
API urlencoding fix
https://github.com/sergejey/majordomo/commit/9f998...
09.07.2019
Minor updates
(SergeJey)
Minor updates
09.07.2019
Merge pull request #580 from AKEB/alpha
(SergeJey)
Fix syntax error
https://github.com/sergejey/majordomo/commit/92403...
08.07.2019
Serial setting update
(SergeJey)
https://github.com/sergejey/majordomo/commit/807a1...
01.07.2019
Update .htaccess
(SergeJey)
Update .htaccess
Security update
https://github.com/sergejey/majordomo/commit/a79af...
26.06.2019
(SergeJey)
System devices sync fix
https://github.com/sergejey/majordomo/commit/b30e2...
Обсуждение (2) (0)
26.06.2019
Update cycle_phistory.php
(SergeJey)
24.06.2019
Minor updates
(SergeJey)
Minor updates
https://github.com/sergejey/majordomo/commit/483d9...
13.06.2019
Homekit sync update
(SergeJey)
Homekit sync update
https://github.com/sergejey/majordomo/commit/209dd...
Обсуждение (1) (0)
06.06.2019
Performance tweaks
(SergeJey)
Performance tweaks
Experimenting with performance improvement :)
https://github.com/sergejey/majordomo/commit/59b28...
06.06.2019
Merge pull request #565 from tarasfrompir/patch-3
(SergeJey)
https://github.com/sergejey/majordomo/commit/f39cb...
06.06.2019
Merge pull request #563 from tarasfrompir/patch-1
(SergeJey)
Update Chromecast.php
https://github.com/sergejey/majordomo/commit/31e6a...
05.06.2019
Performance tweaks
(SergeJey)
Performance tweaks
https://github.com/sergejey/majordomo/commit/324e8...
03.06.2019
Merge pull request #557 from tarasfrompir/patch-4
(SergeJey)
Для правильного обновления инфы последней активности терминалов
https://github.com/sergejey/majordomo/commit/19a6b...
29.05.2019
Fixes
(SergeJey)
Fixes
27.05.2019
Fixes and updates
(SergeJey)
Fixes and updates
14.05.2019
Minor update
(SergeJey)
Minor update
13.05.2019
Merge pull request #552 from Alexandr-logrus/alpha
(SergeJey)
fix
https://github.com/sergejey/majordomo/commit/06320...
13.05.2019
Merge pull request #551 from Alexandr-logrus/alpha
(SergeJey)
fix
https://github.com/sergejey/majordomo/commit/b047d...
13.05.2019
Merge pull request #550 from Alexandr-logrus/alpha
(SergeJey)
fix
https://github.com/sergejey/majordomo/commit/87c26...
11.05.2019
Merge pull request #549 from Alexandr-logrus/alpha
(SergeJey)
fix
https://github.com/sergejey/majordomo/commit/19a20...
10.05.2019
Merge pull request #548 from tarasfrompir/patch-2
(SergeJey)
https://github.com/sergejey/majordomo/commit/fd0f3...
09.05.2019
Merge pull request #546 from Alexandr-logrus/alpha
(SergeJey)
fix
https://github.com/sergejey/majordomo/commit/bcc6e...
08.05.2019
Merge pull request #545 from Alexandr-logrus/alpha
(SergeJey)
smallfix
https://github.com/sergejey/majordomo/commit/975f5...
08.05.2019
Fixes
(SergeJey)
Fixes
04.05.2019
Merge pull request #540 from Alexandr-logrus/alpha
(SergeJey)
fix
https://github.com/sergejey/majordomo/commit/a52a6...
03.05.2019
Merge pull request #537 from Alexandr-logrus/alpha
(SergeJey)
Alpha
https://github.com/sergejey/majordomo/commit/26bfc...
02.05.2019
Minor fixes
(SergeJey)
Minor fixes
02.05.2019
Merge pull request #535 from tarasfrompir/patch-2
(SergeJey)
https://github.com/sergejey/majordomo/commit/cf3ce...
02.05.2019
(SergeJey)
Обсуждение (3) (1)
02.05.2019
Merge pull request #533 from tarasfrompir/patch-5
(SergeJey)
Отображать порт мажордроида включено
https://github.com/sergejey/majordomo/commit/8dfda...
30.04.2019
Merge pull request #531 from tarasfrompir/patch-2
(SergeJey)
https://github.com/sergejey/majordomo/commit/7dfce...
29.04.2019
Simple Devices links config
(SergeJey)
29.04.2019
Merge pull request #529 from Anisan/patch-1
(SergeJey)
users list view avatar and color
https://github.com/sergejey/majordomo/commit/8662e...
26.04.2019
Dimmers update
(SergeJey)
Dimmers update
25.04.2019
(SergeJey)
Homebridge sync fix
https://github.com/sergejey/majordomo/commit/4eb77...
25.04.2019
Updates
(SergeJey)
Updates
23.04.2019
Update nobodyhomemode_activate.php
(SergeJey)
Timer cleanup when activated
https://github.com/sergejey/majordomo/commit/d24b2...
21.04.2019
Minor updates
(SergeJey)
Minor updates
https://github.com/sergejey/majordomo/commit/518c3...
Обсуждение (2) (0)
19.04.2019
Terminals update
(SergeJey)
Terminals update
19.04.2019
API update and cleanup
(SergeJey)
18.04.2019
(SergeJey)
Dimmer linked action call fixed
https://github.com/sergejey/majordomo/commit/4f1fd...
16.04.2019
Minor fixes
(SergeJey)
Minor fixes
12.04.2019
Blockly fix
(SergeJey)
Blockly fix
Обсуждение (2) (0)
12.04.2019
Merge pull request #522 from tarasfrompir/patch-3
(SergeJey)
Update default.php
https://github.com/sergejey/majordomo/commit/8a1ca...
11.04.2019
Plans updated
(SergeJey)
Plans updated
11.04.2019
Merge pull request #521 from tarasfrompir/patch-1
(SergeJey)
Исправлено получение информации от Гугл хом колонки
https://github.com/sergejey/majordomo/commit/6837f...
10.04.2019
Updates
(SergeJey)
Updates
10.04.2019
(SergeJey)
DIR_MODULES, DIR_TEMPLATES updated for sample config file
https://github.com/sergejey/majordomo/commit/c635c...
10.04.2019
Minor updates
(SergeJey)
Minor updates
09.04.2019
Simple Devices fix
(SergeJey)
Simple Devices fix
09.04.2019
Module installation and update optimizing
(SergeJey)
https://github.com/sergejey/majordomo/commit/30187...
09.04.2019
Merge pull request #515 from tarasfrompir/patch-4
(SergeJey)
Update recognizeTime
https://github.com/sergejey/majordomo/commit/36155...
08.04.2019
Merge pull request #511 from tarasfrompir/patch-1
(SergeJey)
Update ua.php
https://github.com/sergejey/majordomo/commit/84153...
08.04.2019
Templates parsing fix
(SergeJey)
https://github.com/sergejey/majordomo/commit/43e08...
08.04.2019
Fixes
(SergeJey)
Fixes
07.04.2019
(SergeJey)
Object clone function fix
https://github.com/sergejey/majordomo/commit/0c62d...
Обсуждение (3) (0)
04.04.2019
Merge pull request #505 from tarasfrompir/patch-11
(SergeJey)
https://github.com/sergejey/majordomo/commit/88c2c...
04.04.2019
(SergeJey)
Drop column fix
https://github.com/sergejey/majordomo/commit/22ff1...
04.04.2019
Connect updates
(SergeJey)
Connect updates
04.04.2019
Merge pull request #502 from tarasfrompir/patch-7
(SergeJey)
Доработка к предыдущим реквестам
https://github.com/sergejey/majordomo/commit/25db6...
04.04.2019
Merge pull request #501 from tarasfrompir/patch-6
(SergeJey)
внес обсуждаемые изменения
https://github.com/sergejey/majordomo/commit/2a552...
04.04.2019
Merge pull request #500 from tarasfrompir/patch-5
(SergeJey)
Добавлено поле кода языка
https://github.com/sergejey/majordomo/commit/4ae13...
04.04.2019
Merge pull request #499 from tarasfrompir/patch-4
(SergeJey)
Исправлена отписка от события
https://github.com/sergejey/majordomo/commit/3cbab...
03.04.2019
Merge pull request #497 from DarkVeter/fix-websocket
(SergeJey)
websockets fix
https://github.com/sergejey/majordomo/commit/09a56...
02.04.2019
Media browser update
(SergeJey)
27.03.2019
(SergeJey)
SOURCE field length fix
https://github.com/sergejey/majordomo/commit/93fb8...
26.03.2019
Merge pull request #495 from Anisan/patch-5
(SergeJey)
Simple Devices: fix run sheduler task
https://github.com/sergejey/majordomo/commit/9fe50...
25.03.2019
(SergeJey)
https://github.com/sergejey/majordomo/commit/12378...
24.03.2019
Merge pull request #491 from tarasfrompir/patch-2
(SergeJey)
Виправлено відображення полів необхідних для відповідного типу термінала
https://github.com/sergejey/majordomo/commit/ba101...
20.03.2019
Minor updates
(SergeJey)
Minor updates
18.03.2019
d3 javascript library added
(SergeJey)
https://github.com/sergejey/majordomo/commit/8a1e5...
18.03.2019
Gauge plans component added
(SergeJey)
18.03.2019
Plan Components
(SergeJey)
Plan Components
18.03.2019
Merge pull request #489 from dimaw/patch-1
(SergeJey)
контроль доступа с терминалов
https://github.com/sergejey/majordomo/commit/c0007...
16.03.2019
Merge pull request #486 from tarasfrompir/patch-1
(SergeJey)
исправлено сохранение выбора скрипта для устройств онлайн
https://github.com/sergejey/majordomo/commit/791af...
16.03.2019
New code writing option
(SergeJey)
New option for automation scenarios: Devices. Just add devices with their states with no code or blocks.
https://github.com/sergejey/majordomo/commit/1d11f...
15.03.2019
Updates
(SergeJey)
Updates
13.03.2019
Merge pull request #485 from Anisan/patch-4
(SergeJey)
fix market list
https://github.com/sergejey/majordomo/commit/fd93e...
12.03.2019
Merge pull request #483 from tigerxp/alpha
(SergeJey)
Fixed: mysqldump for non-localhost database
https://github.com/sergejey/majordomo/commit/0b1b0...
10.03.2019
Update plans.class.php
(SergeJey)
Plans fixes
https://github.com/sergejey/majordomo/commit/c9974...
09.03.2019
Updates
(SergeJey)
Updates
07.03.2019
Plans update
(SergeJey)
Plans update
07.03.2019
Updates
(SergeJey)
Updates
07.03.2019
Updates
(SergeJey)
Updates
05.03.2019
Plans fix
(SergeJey)
Plans fix
https://github.com/sergejey/majordomo/commit/2fe16...
03.03.2019
3rd-party plugins
(SergeJey)
3rd-party plugins
03.03.2019
CONNECT section update
(SergeJey)
01.03.2019
(SergeJey)
Plans warning fix
https://github.com/sergejey/majordomo/commit/21c99...
01.03.2019
Update scenes.tpl
(SergeJey)
Update scenes.tpl
Javascript caching fix
https://github.com/sergejey/majordomo/commit/abf0f...
28.02.2019
Merge pull request #473 from Fat-Zer/fix-blank-kcfinder
(SergeJey)
kcfinder: fix a silent blank page on critial errors
https://github.com/sergejey/majordomo/commit/a4efe...
28.02.2019
Merge branch 'master' into alpha
(SergeJey)
https://github.com/sergejey/majordomo/commit/6dff3...
27.02.2019
Plans updates
(SergeJey)
Plans updates
26.02.2019
Plans module
(SergeJey)
Plans module
20.02.2019
Cleanup
(SergeJey)
Cleanup
https://github.com/sergejey/majordomo/commit/d4dbd...
20.02.2019
Minor updates
(SergeJey)
Minor updates
14.02.2019
Bug fix
(SergeJey)
Bug fix
https://github.com/sergejey/majordomo/commit/67bbc...
14.02.2019
Scenes update
(SergeJey)
Scenes update
10.02.2019
Blockly fixes and Scripts update
(SergeJey)
09.02.2019
Control Panel updates
(SergeJey)
08.02.2019
Blockly timer fix
(SergeJey)
Blockly timer fix
https://github.com/sergejey/majordomo/commit/3d54f...
31.01.2019
(SergeJey)
https://github.com/sergejey/majordomo/commit/e8ee7...
30.01.2019
Merge pull request #461 from Anisan/patch-1
(SergeJey)
API: add devices field favorite
https://github.com/sergejey/majordomo/commit/95e68...
29.01.2019
Merge pull request #466 from tarasfrompir/patch-1
(SergeJey)
https://github.com/sergejey/majordomo/commit/ecd12...
25.01.2019
Updates
(SergeJey)
Updates
23.01.2019
Merge pull request #465 from tarasfrompir/alpha
(SergeJey)
Add icon for Optimiser
https://github.com/sergejey/majordomo/commit/f4618...
23.01.2019
Merge pull request #464 from tarasfrompir/patch-5
(SergeJey)
Исправлен метод движения для IP Камеры
https://github.com/sergejey/majordomo/commit/d900e...
22.01.2019
Merge pull request #463 from tarasfrompir/patch-4
(SergeJey)
Ускорена реакция на первое сообщение системы Хромкаста
https://github.com/sergejey/majordomo/commit/f816f...
21.01.2019
Update Rooms_updateActivityStatus.php
(SergeJey)
Nobody home mode was not setting correct, fixed.
https://github.com/sergejey/majordomo/commit/ca72a...
17.01.2019
Updates
(SergeJey)
Updates
16.01.2019
Merge pull request #453 from tarasfrompir/patch-1
(SergeJey)
стандартизирован код функции СЕЙ
https://github.com/sergejey/majordomo/commit/1d20d...
15.01.2019
(SergeJey)
Linked method bug fixed (problem with property update by MQTT module).
https://github.com/sergejey/majordomo/commit/55ae2...
15.01.2019
(SergeJey)
OnChange method call fixed
https://github.com/sergejey/majordomo/commit/34e9c...
13.01.2019
Updates
(SergeJey)
Updates
11.01.2019
Minor fixes
(SergeJey)
Minor fixes
09.01.2019
Simple devices update
(SergeJey)
05.01.2019
Session fix
(SergeJey)
Session fix
https://github.com/sergejey/majordomo/commit/f9688...
04.01.2019
Simple Devices: new link
(SergeJey)
03.01.2019
User session fix
(SergeJey)
User session fix
03.01.2019
(SergeJey)
03.01.2019
Session fix
(SergeJey)
Session fix
02.01.2019
Merge pull request #455 from thesoultaker48/alpha
(SergeJey)
DEVICES_COMMAND_CONFIRMATION
https://github.com/sergejey/majordomo/commit/398c0...
30.12.2018
Merge pull request #454 from thesoultaker48/alpha
(SergeJey)
Removed scroll bar when selecting terminals
https://github.com/sergejey/majordomo/commit/354fe...
30.12.2018
Control Panel design updates
(SergeJey)
30.12.2018
New control panel design tweaks
(SergeJey)
Menu size fixes
https://github.com/sergejey/majordomo/commit/c11fc...
29.12.2018
(SergeJey)
Mobile-friendly design update for Control Panel
https://github.com/sergejey/majordomo/commit/a68d7...
29.12.2018
terminal name fix, api minor tweak
(SergeJey)
https://github.com/sergejey/majordomo/commit/2be62...
27.12.2018
Update app_player.class.php
(SergeJey)
bug fixed
https://github.com/sergejey/majordomo/commit/fcbae...
27.12.2018
Minor bug-fixing
(SergeJey)
Minor bug-fixing
https://github.com/sergejey/majordomo/commit/02bf0...
24.12.2018
Simple devices updates
(SergeJey)
Simple Devices: history data opens in parent fancybox
Market: copy warning removed
https://github.com/sergejey/majordomo/commit/0daea...
20.12.2018
Merge pull request #449 from Siorinex/patch-2
(SergeJey)
Исправление косяка с не-админом
https://github.com/sergejey/majordomo/commit/24946...
20.12.2018
Merge pull request #447 from tarasfrompir/patch-13
(SergeJey)
исправлено отображение терминалов по запросу $session->data['TERMINAL']);
https://github.com/sergejey/majordomo/commit/926ae...
19.12.2018
Merge pull request #446 from directman66/patch-9
(SergeJey)
Update xray.html
https://github.com/sergejey/majordomo/commit/6c23c...
19.12.2018
Merge pull request #444 from directman66/patch-6
(SergeJey)
Update xray.class.php
https://github.com/sergejey/majordomo/commit/5b040...
17.12.2018
Merge pull request #442 from directman66/patch-4
(SergeJey)
Update zh.php
https://github.com/sergejey/majordomo/commit/fa2d8...
17.12.2018
Chinese flag added
(SergeJey)
Chinese flag added
17.12.2018
Disable cycles loggin
(SergeJey)
16.12.2018
Fixes
(SergeJey)
Fixes
13.12.2018
Merge pull request #436 from tarasfrompir/patch-12
(SergeJey)
Убраны ненужные сообщения в систему
https://github.com/sergejey/majordomo/commit/f1592...
13.12.2018
Merge pull request #435 from tarasfrompir/patch-11
(SergeJey)
Убран sleep(4) из таймера, чтобы не вешать систему на 4 секунды
https://github.com/sergejey/majordomo/commit/74fbe...
12.12.2018
Merge pull request #434 from tarasfrompir/patch-10
(SergeJey)
Уваличены задержки для срабатывания на слабшем оборудовании.
https://github.com/sergejey/majordomo/commit/22a36...
12.12.2018
Merge pull request #432 from tarasfrompir/patch-8
(SergeJey)
Убраны дебмесы в систему - они не нужны
https://github.com/sergejey/majordomo/commit/f8a87...
12.12.2018
Merge pull request #430 from tarasfrompir/patch-6
(SergeJey)
Добавлена функция seek для возвращения на текущую позицию проигрываемого контента
https://github.com/sergejey/majordomo/commit/efb1e...
12.12.2018
Settings filter update option
(SergeJey)
12.12.2018
Merge pull request #429 from olehs/patch-7
(SergeJey)
fixed subscribeToEvent priority clearance
https://github.com/sergejey/majordomo/commit/df705...
11.12.2018
Push-notifications
(SergeJey)
Push-notifications
11.12.2018
Merge pull request #428 from tarasfrompir/patch-5
(SergeJey)
уменьшен приоритет терминалов.
https://github.com/sergejey/majordomo/commit/5529f...
10.12.2018
Merge pull request #426 from tarasfrompir/patch-3
(SergeJey)
Исправлено получение статуса плеера ДНЛА
https://github.com/sergejey/majordomo/commit/3a8bb...
10.12.2018
Devices: groups objects
(SergeJey)
10.12.2018
Merge pull request #425 from tarasfrompir/patch-2
(SergeJey)
Update ua.php
https://github.com/sergejey/majordomo/commit/4e894...
10.12.2018
Devices scheduler
(SergeJey)
Devices scheduler
10.12.2018
Merge pull request #424 from tarasfrompir/patch-1
(SergeJey)
callMethodSafe
https://github.com/sergejey/majordomo/commit/d744b...
Обсуждение (6) (1)
09.12.2018
Minor updates
(SergeJey)
Minor updates
09.12.2018
Merge pull request #421 from tarasfrompir/alpha
(SergeJey)
change name img system error
https://github.com/sergejey/majordomo/commit/3079c...
09.12.2018
Merge pull request #420 from tarasfrompir/patch-5
(SergeJey)
Убрана задержка ДНЛА библиотеке - чтобы не вешать систему и добавлен вариант 2 на вос…
https://github.com/sergejey/majordomo/commit/5c7d4...
07.12.2018
Merge pull request #418 from tarasfrompir/patch-4
(SergeJey)
Исправлены мелкие недочеты
https://github.com/sergejey/majordomo/commit/d58bd...
07.12.2018
Merge pull request #417 from tarasfrompir/patch-3
(SergeJey)
Создано запись для возвращения воспроизводимого контента на терминалах
https://github.com/sergejey/majordomo/commit/7641b...
06.12.2018
Merge pull request #416 from tarasfrompir/patch-2
(SergeJey)
Исправил кавычки
https://github.com/sergejey/majordomo/commit/ce34a...
04.12.2018
Merge pull request #415 from tarasfrompir/patch-1
(SergeJey)
Update ua.php
https://github.com/sergejey/majordomo/commit/a2351...
02.12.2018
Minor fixes and updates
(SergeJey)
02.12.2018
Merge pull request #413 from tarasfrompir/patch-6
(SergeJey)
Фильтрация терминалов с свойством CANTTS
https://github.com/sergejey/majordomo/commit/d3714...
30.11.2018
Fix
(SergeJey)
Fix
"Ask" command processing fix in terminals
https://github.com/sergejey/majordomo/commit/4de51...
30.11.2018
Updates
(SergeJey)
Updates
30.11.2018
Merge pull request #411 from tarasfrompir/patch-6
(SergeJey)
Добавлено сообщение "Неизвестная команда"
https://github.com/sergejey/majordomo/commit/eceeb...
Обсуждение (1) (1)
30.11.2018
Merge pull request #410 from tarasfrompir/patch-7
(SergeJey)
Обновлен перевод украинского языка
https://github.com/sergejey/majordomo/commit/24c5f...
28.11.2018
Merge pull request #406 from Alexandr-logrus/alpha
(SergeJey)
fix
https://github.com/sergejey/majordomo/commit/abb3a...
27.11.2018
Updates
(SergeJey)
Updates
26.11.2018
Merge pull request #408 from tarasfrompir/patch-5
(SergeJey)
Временно отключено поскольку функция сейту делает это
https://github.com/sergejey/majordomo/commit/1143f...
25.11.2018
Update SMotions_motionDetected.php
(SergeJey)
Motion detection fix
https://github.com/sergejey/majordomo/commit/5d7fa...
24.11.2018
(SergeJey)
ASK command fix
https://github.com/sergejey/majordomo/commit/218e1...
24.11.2018
Merge pull request #407 from tarasfrompir/patch-4
(SergeJey)
Update function getPlayerStatus
https://github.com/sergejey/majordomo/commit/514b1...
23.11.2018
(SergeJey)
MajorDroid TTS fix
https://github.com/sergejey/majordomo/commit/88d38...
23.11.2018
(SergeJey)
https://github.com/sergejey/majordomo/commit/0d3d9...
Обсуждение (1) (1)
23.11.2018
Update SDimmers_levelWorkUpdated.php
(SergeJey)
fix
https://github.com/sergejey/majordomo/commit/dbb69...
22.11.2018
Merge pull request #403 from tarasfrompir/patch-3
(SergeJey)
Переработка получения текущего файла DLNA плеера
https://github.com/sergejey/majordomo/commit/cca9e...
21.11.2018
Merge pull request #402 from tarasfrompir/patch-2
(SergeJey)
Для очереди сообщений убрано level message
https://github.com/sergejey/majordomo/commit/38ab5...
21.11.2018
Merge pull request #400 from thesoultaker48/alpha
(SergeJey)
Added the play_terminal and session_terminal properties for the terminal object
https://github.com/sergejey/majordomo/commit/412c5...
20.11.2018
Update
(SergeJey)
Update
Обсуждение (2) (2)
20.11.2018
Merge pull request #397 from tarasfrompir/patch-2
(SergeJey)
Исправлена мелкая ошибка
https://github.com/sergejey/majordomo/commit/55874...
20.11.2018
Merge pull request #396 from tarasfrompir/patch-1
(SergeJey)
Изменения для отрабатывания очереди
https://github.com/sergejey/majordomo/commit/b9d24...
20.11.2018
Merge pull request #395 from tarasfrompir/alpha
(SergeJey)
Вынесена необходимая задержка из функции getMediaDurationSeconds в терминалы
https://github.com/sergejey/majordomo/commit/b1441...
19.11.2018
Merge pull request #394 from tarasfrompir/alpha
(SergeJey)
Update dnla.addon.php
https://github.com/sergejey/majordomo/commit/9490d...
18.11.2018
Merge pull request #393 from tarasfrompir/alpha
(SergeJey)
https://github.com/sergejey/majordomo/commit/b1f61...
18.11.2018
Updates
(SergeJey)
Updates
16.11.2018
Create list.html
(SergeJey)
Create list.html
Market fix
https://github.com/sergejey/majordomo/commit/c73e2...
Обсуждение (2) (1)
16.11.2018
Market updates
(SergeJey)
Market updates
16.11.2018
Market module update
(SergeJey)
Dynamic data loading for category listing and searches
https://github.com/sergejey/majordomo/commit/ed1ca...
16.11.2018
Merge pull request #391 from tarasfrompir/alpha
(SergeJey)
Updated status for DLNA terminals
https://github.com/sergejey/majordomo/commit/ca12d...
16.11.2018
Merge pull request #390 from tarasfrompir/alpha
(SergeJey)
Add function getPlayerStatus
https://github.com/sergejey/majordomo/commit/553fb...
15.11.2018
Minor update
(SergeJey)
Minor update
14.11.2018
(SergeJey)
https://github.com/sergejey/majordomo/commit/182f6...
14.11.2018
Merge pull request #388 from tarasfrompir/alpha
(SergeJey)
Функция для создания очереди воспроизведения сообщений в терминалах
https://github.com/sergejey/majordomo/commit/bb23d...
14.11.2018
Merge pull request #387 from tarasfrompir/alpha
(SergeJey)
Исправлено состояние терминалов - было всегда в оффлане
https://github.com/sergejey/majordomo/commit/ab8f2...
14.11.2018
Update modules/objects/objects.class.php
(SergeJey)
Data structure fix
https://github.com/sergejey/majordomo/commit/b5733...
13.11.2018
Update modules/devices/processCommand.inc.php
(SergeJey)
Fixed processing turnon/off command (in russian)
https://github.com/sergejey/majordomo/commit/de152...
13.11.2018
Minor updates
(SergeJey)
Minor updates
getURLBackground fixes
https://github.com/sergejey/majordomo/commit/9cd15...
11.11.2018
Fixes
(SergeJey)
Fixes
09.11.2018
Update modules/terminals/terminals.class.php
(SergeJey)
MAIN terminal record is not required for sending notifications to ChromeCast/DLNA terminals.
https://github.com/sergejey/majordomo/commit/83a96...
09.11.2018
TTS structure update
(SergeJey)
https://github.com/sergejey/majordomo/commit/8b70f...
Обсуждение (16) (2)
08.11.2018
Merge pull request #385 from tarasfrompir/alpha
(SergeJey)
Убрано срабатывание на подписку на sayReply и ask в терминалах...
https://github.com/sergejey/majordomo/commit/44d38...
07.11.2018
Merge pull request #384 from tarasfrompir/alpha
(SergeJey)
Доработан ДЛНА аддон и получение информации о состоянии терминала
https://github.com/sergejey/majordomo/commit/5d2e0...
07.11.2018
Merge pull request #381 from tarasfrompir/alpha
(SergeJey)
Заменил очередь опроса на устройства
https://github.com/sergejey/majordomo/commit/78e7f...
07.11.2018
Merge pull request #380 from tarasfrompir/alpha
(SergeJey)
Update terminals.class.php - worning убран
https://github.com/sergejey/majordomo/commit/d5c4b...
Обсуждение (1) (2)
06.11.2018
Greek language added
(SergeJey)
https://github.com/sergejey/majordomo/commit/14124...
06.11.2018
Merge pull request #377 from directman66/alpha
(SergeJey)
Update first_start.php
https://github.com/sergejey/majordomo/commit/57d69...
05.11.2018
Merge pull request #374 from tarasfrompir/alpha
(SergeJey)
Убрана задержка на воспроизведение Хромкаст устройств
https://github.com/sergejey/majordomo/commit/985e1...
05.11.2018
Merge pull request #373 from tarasfrompir/alpha
(SergeJey)
Мелкие исправления для терминалов
https://github.com/sergejey/majordomo/commit/2d800...
04.11.2018
Merge pull request #371 from tarasfrompir/alpha
(SergeJey)
проверка евентов для воспроизведения сообщений
https://github.com/sergejey/majordomo/commit/35fdf...
03.11.2018
Update 3rdparty/freeboard/lib/js/thirdparty/head.min.js
(SergeJey)
https://github.com/sergejey/majordomo/commit/73526...
02.11.2018
Merge pull request #369 from tarasfrompir/alpha
(SergeJey)
https://github.com/sergejey/majordomo/commit/d6223...
02.11.2018
Merge pull request #368 from tarasfrompir/alpha
(SergeJey)
добавлено расширение m3u в DLNA терминалы
https://github.com/sergejey/majordomo/commit/3250e...
01.11.2018
Merge pull request #367 from tarasfrompir/alpha
(SergeJey)
Мелкие исправления
https://github.com/sergejey/majordomo/commit/dde2d...
01.11.2018
Merge pull request #366 from tarasfrompir/alpha
(SergeJey)
Исправлено воспроизведение ДЛНА терминалами 101 ру
https://github.com/sergejey/majordomo/commit/c245f...
31.10.2018
Update cms/scenes/styles/informer/style.css.tpl
(SergeJey)
https://github.com/sergejey/majordomo/commit/4c04d...
31.10.2018
Merge pull request #362 from tarasfrompir/alpha
(SergeJey)
Исправлено автоопределение CONTROLL_ADDRESS
https://github.com/sergejey/majordomo/commit/0c57c...
31.10.2018
Merge pull request #361 from tarasfrompir/alpha
(SergeJey)
Вернул назад условие для сообщения.
https://github.com/sergejey/majordomo/commit/2d675...
30.10.2018
Merge pull request #360 from tarasfrompir/alpha
(SergeJey)
https://github.com/sergejey/majordomo/commit/d43f6...
29.10.2018
Merge pull request #358 from tarasfrompir/alpha
(SergeJey)
Исправлена ссылка на файл для воспроизведения сообщений на Терминалах
https://github.com/sergejey/majordomo/commit/99841...
Обсуждение (2) (1)
29.10.2018
Merge pull request #356 from tarasfrompir/alpha
(SergeJey)
Update MediaRenderer DLNA for links with extends
https://github.com/sergejey/majordomo/commit/30476...
29.10.2018
System updates
(SergeJey)
System updates
25.10.2018
Merge pull request #354 from tarasfrompir/alpha
(SergeJey)
Переписано управление звуком DLNA
https://github.com/sergejey/majordomo/commit/2eb1d...
24.10.2018
Merge pull request #352 from thesoultaker48/alpha
(SergeJey)
Small changes
https://github.com/sergejey/majordomo/commit/ab6ab...
24.10.2018
Merge pull request #350 from thesoultaker48/alpha
(SergeJey)
Volume control fix
https://github.com/sergejey/majordomo/commit/8aa9d...
23.10.2018
Merge pull request #349 from tarasfrompir/alpha
(SergeJey)
Rewrite and Update class for DLNA terminals
https://github.com/sergejey/majordomo/commit/b10d5...
22.10.2018
Updates
(SergeJey)
Updates
20.10.2018
Updates
(SergeJey)
Updates
19.10.2018
Merge pull request #348 from AKEB/alpha
(SergeJey)
Can't connect to database
https://github.com/sergejey/majordomo/commit/d6b78...
19.10.2018
Merge pull request #346 from thesoultaker48/alpha
(SergeJey)
Alpha
https://github.com/sergejey/majordomo/commit/776b9...
18.10.2018
Merge pull request #345 from tarasfrompir/alpha
(SergeJey)
Added the field Controll_addres for DNLA terminals
https://github.com/sergejey/majordomo/commit/09286...
17.10.2018
Cycles updates
(SergeJey)
Cycles updates
16.10.2018
Fixes
(SergeJey)
Fixes
16.10.2018
Hebrew language added
(SergeJey)
https://github.com/sergejey/majordomo/commit/5957c...
13.10.2018
Updates
(SergeJey)
Updates
12.10.2018
Merge pull request #340 from thesoultaker48/alpha
(SergeJey)
Fixed conflict with jQuery Mobile
https://github.com/sergejey/majordomo/commit/540d5...
12.10.2018
Merge pull request #339 from tribukhouski/fast_timenow
(SergeJey)
timenow без обращения к базе
https://github.com/sergejey/majordomo/commit/1f2f4...
11.10.2018
Merge pull request #338 from thesoultaker48/alpha
(SergeJey)
Small fixes
https://github.com/sergejey/majordomo/commit/6acd2...
11.10.2018
Merge pull request #337 from AKEB/alpha
(SergeJey)
Работа с RGB устройствами
https://github.com/sergejey/majordomo/commit/1c557...
11.10.2018
Merge pull request #336 from thesoultaker48/alpha
(SergeJey)
Removed forced loading of darkness css
https://github.com/sergejey/majordomo/commit/9355b...
11.10.2018
Merge pull request #335 from AKEB/alpha
(SergeJey)
Правка ошибки
https://github.com/sergejey/majordomo/commit/76258...
10.10.2018
Merge pull request #334 from AKEB/alpha
(SergeJey)
Правка ошибки при отсутствии объекта
https://github.com/sergejey/majordomo/commit/4ef41...
10.10.2018
Merge pull request #332 from thesoultaker48/alpha
(SergeJey)
New template for app_player
https://github.com/sergejey/majordomo/commit/2c0ab...
10.10.2018
Merge pull request #331 from thesoultaker48/alpha
(SergeJey)
Directory separator fix
https://github.com/sergejey/majordomo/commit/851c0...
09.10.2018
Merge pull request #330 from Alexandr-logrus/alpha1
(SergeJey)
мелкие правки
https://github.com/sergejey/majordomo/commit/70f18...
09.10.2018
Scenes minor fix
(SergeJey)
Scenes minor fix
https://github.com/sergejey/majordomo/commit/dd83d...
08.10.2018
Merge pull request #321 from AKEB/alpha
(SergeJey)
https://github.com/sergejey/majordomo/commit/72399...
Обсуждение (11) (2)
08.10.2018
Scenes update
(SergeJey)
Scenes update
07.10.2018
Merge pull request #328 from YuriiRadio/patch-7
(SergeJey)
Update ua.php
https://github.com/sergejey/majordomo/commit/70705...
07.10.2018
Simple Devices update
(SergeJey)
04.10.2018
Merge pull request #327 from thesoultaker48/alpha
(SergeJey)
Small changes in the player
https://github.com/sergejey/majordomo/commit/65061...
04.10.2018
Merge pull request #326 from thesoultaker48/alpha
(SergeJey)
LMS: final release
https://github.com/sergejey/majordomo/commit/c2f2e...
04.10.2018
History data fix
(SergeJey)
History data fix
04.10.2018
Merge pull request #324 from thesoultaker48/alpha
(SergeJey)
LMS: pl_get optimize
https://github.com/sergejey/majordomo/commit/638a8...
03.10.2018
Updates
(SergeJey)
Updates
03.10.2018
Websockets minimize log
(SergeJey)
https://github.com/sergejey/majordomo/commit/d9867...
03.10.2018
Merge pull request #323 from thesoultaker48/alpha
(SergeJey)
Fix for app_mediabrowser
https://github.com/sergejey/majordomo/commit/717db...
02.10.2018
Merge pull request #319 from AKEB/alpha
(SergeJey)
Синхронизация простого устройства sensor_light с HomeBridge
https://github.com/sergejey/majordomo/commit/6a851...
01.10.2018
Merge pull request #318 from thesoultaker48/alpha
(SergeJey)
Small fixes
https://github.com/sergejey/majordomo/commit/79b60...
28.09.2018
Merge pull request #315 from thesoultaker48/alpha
(SergeJey)
Fixed a bug that occurs when some properties are missing
https://github.com/sergejey/majordomo/commit/d33d1...
28.09.2018
Merge pull request #314 from thesoultaker48/alpha
(SergeJey)
Small fix in control_modules.class.php
https://github.com/sergejey/majordomo/commit/67b02...
28.09.2018
Merge pull request #313 from thesoultaker48/alpha
(SergeJey)
Volume control fix
https://github.com/sergejey/majordomo/commit/566e2...
27.09.2018
Merge pull request #312 from Anisan/alpha
(SergeJey)
fix default ws port
https://github.com/sergejey/majordomo/commit/3bc41...
27.09.2018
Merge pull request #311 from Anisan/alpha
(SergeJey)
new websocket server
https://github.com/sergejey/majordomo/commit/1cd2e...
26.09.2018
Websockets fix
(SergeJey)
Websockets fix
https://github.com/sergejey/majordomo/commit/b4bae...
26.09.2018
(SergeJey)
24.09.2018
Merge pull request #310 from thesoultaker48/alpha
(SergeJey)
Automatic addition slash at the end of the path
https://github.com/sergejey/majordomo/commit/b8530...
24.09.2018
Merge pull request #308 from tarasfrompir/patch-2
(SergeJey)
Добавлены ответы устройства в Терминале ДНЛА
https://github.com/sergejey/majordomo/commit/008ad...
24.09.2018
Merge pull request #307 from thesoultaker48/alpha
(SergeJey)
Addon Kodi (for terminals)
https://github.com/sergejey/majordomo/commit/6c459...
24.09.2018
Merge pull request #306 from tarasfrompir/patch-1
(SergeJey)
Исправлено работу с WMP в ДНЛА терминал
https://github.com/sergejey/majordomo/commit/2c111...
24.09.2018
Dashboards update
(SergeJey)
Dashboards update
24.09.2018
Merge pull request #304 from Anisan/alpha
(SergeJey)
fix get name property from db
https://github.com/sergejey/majordomo/commit/59147...
23.09.2018
Merge pull request #303 from Alexandr-logrus/alpha
(SergeJey)
Update devices_structure.inc.php
https://github.com/sergejey/majordomo/commit/92ebe...
22.09.2018
Updates
(SergeJey)
Updates
21.09.2018
Connect FIX
(SergeJey)
Connect FIX
SSL connection fix
https://github.com/sergejey/majordomo/commit/cf325...
20.09.2018
Merge pull request #297 from thesoultaker48/alpha
(SergeJey)
Bug fixes
https://github.com/sergejey/majordomo/commit/3d028...
19.09.2018
Merge pull request #296 from thesoultaker48/alpha
(SergeJey)
Small fixes
https://github.com/sergejey/majordomo/commit/f7658...
18.09.2018
Merge pull request #295 from Anisan/alpha
(SergeJey)
API: get object by class
https://github.com/sergejey/majordomo/commit/52581...
17.09.2018
Simple devices iOs update
(SergeJey)
17.09.2018
Merge pull request #294 from thesoultaker48/alpha
(SergeJey)
Bug fixes
https://github.com/sergejey/majordomo/commit/cb608...
17.09.2018
Dashboards fix
(SergeJey)
Dashboards fix
15.09.2018
Updates
(SergeJey)
Updates
12.09.2018
Merge pull request #291 from thesoultaker48/alpha
(SergeJey)
VLC: backward compatibility fix
https://github.com/sergejey/majordomo/commit/99fd6...
11.09.2018
Updates
(SergeJey)
Updates
Device cloud-sync routine update.
https://github.com/sergejey/majordomo/commit/676e9...
10.09.2018
Merge pull request #289 from thesoultaker48/alpha
(SergeJey)
VLC over HTTP: Added authorization check, optimized code
https://github.com/sergejey/majordomo/commit/332f0...
10.09.2018
Updates
(SergeJey)
Updates
10.09.2018
Merge pull request #288 from thesoultaker48/alpha
(SergeJey)
Fixed bug with processing of numeric parameter "0"
https://github.com/sergejey/majordomo/commit/568ef...
07.09.2018
(SergeJey)
06.09.2018
CloudSync updates
(SergeJey)
CloudSync updates
06.09.2018
Merge pull request #287 from thesoultaker48/alpha
(SergeJey)
Code revision and bug fixes
https://github.com/sergejey/majordomo/commit/78ba1...
06.09.2018
Merge pull request #285 from thesoultaker48/alpha
(SergeJey)
Redesigned the app_player for more effective support for addons.
https://github.com/sergejey/majordomo/commit/14850...
05.09.2018
Connect update
(SergeJey)
Connect update
04.09.2018
API updates
(SergeJey)
API updates
Обсуждение (2) (2)
04.09.2018
Merge pull request #284 from thesoultaker48/alpha
(SergeJey)
Changes to the new player management interface (backward compatibility is preserved).
https://github.com/sergejey/majordomo/commit/b1c7b...
02.09.2018
Merge pull request #283 from thesoultaker48/alpha
(SergeJey)
vlcweb update
https://github.com/sergejey/majordomo/commit/8fc35...
29.08.2018
(SergeJey)
Обсуждение (0) (4)
28.08.2018
Updates
(SergeJey)
Updates
26.08.2018
Updates
(SergeJey)
Updates
24.08.2018
Merge pull request #276 from Anisan/alpha
(SergeJey)
Simple devices: open/close
https://github.com/sergejey/majordomo/commit/a303a...
24.08.2018
Merge pull request #278 from Gelezako/patch-5
(SergeJey)
добавлена локализация панели управления
https://github.com/sergejey/majordomo/commit/eeb6e...
22.08.2018
Merge pull request #275 from savenko-egor/patch-2
(SergeJey)
Fix problem with large image on apps page.
https://github.com/sergejey/majordomo/commit/c3d1f...
22.08.2018
Pinghosts icon update
(SergeJey)
https://github.com/sergejey/majordomo/commit/f3657...
20.08.2018
Merge pull request #272 from thesoultaker48/alpha
(SergeJey)
Fixed error for wiki_hint
https://github.com/sergejey/majordomo/commit/21b4b...
17.08.2018
Updates
(SergeJey)
Updates
  • Wiki url fixed (for inline help)
  • phpMQTT library included by default (required for Connect cloud sync)
  • pinghosts module now have "app" interface
  • Scenes -- fixe javascript error with loading bootstrap before jquery.
    https://github.com/sergejey/majordomo/commit/e8c18...
14.08.2018
History limit update
(SergeJey)
https://github.com/sergejey/majordomo/commit/efa43...
Обсуждение (9) (2)
14.08.2018
ChromeCast support updated
(SergeJey)
Fixed Chromecast Players support (tested with GoogleTV, GoogleHome)
https://github.com/sergejey/majordomo/commit/fdf05...
Обсуждение (11) (4)
13.08.2018
(SergeJey)
https://github.com/sergejey/majordomo/commit/758b1...
09.08.2018
Merge pull request #264 from Anisan/alpha
(SergeJey)
optimize cycle phistory
https://github.com/sergejey/majordomo/commit/54983...
Обсуждение (1) (2)
09.08.2018
Scene import fix
(SergeJey)
Scene import fix
https://github.com/sergejey/majordomo/commit/6533e...
01.08.2018
(SergeJey)
https://github.com/sergejey/majordomo/commit/ac51d...
31.07.2018
Merge pull request #262 from tarasfrompir/patch-2
(SergeJey)
Update ua.php
https://github.com/sergejey/majordomo/commit/245a2...
30.07.2018
Simple Devices
(SergeJey)
Simple Devices
Improving voice command processing
https://github.com/sergejey/majordomo/commit/f7ea5...
30.07.2018
Updates
(SergeJey)
Updates
  • Scenes: element image field database error fix
  • "Safe" functions added (saySafe, sayToSafe, sayReplySafe, processSubscriptionsSafe)
  • Simple Devices: timers added to voice commands ("turn on device for 5 seconds", "in 5 minutes turn off device")
    https://github.com/sergejey/majordomo/commit/11fe3...
Обсуждение (6) (3)
28.07.2018
Remove some files
(SergeJey)
Remove some files
Removing some not-used files
https://github.com/sergejey/majordomo/commit/dca6a...
26.07.2018
Merge pull request #249 from tarasfrompir/patch-4
(SergeJey)
include ukranian languige
https://github.com/sergejey/majordomo/commit/0472d...
26.07.2018
Merge pull request #248 from tarasfrompir/patch-3
(SergeJey)
Мелкое исправление
https://github.com/sergejey/majordomo/commit/11c55...
22.07.2018
Merge pull request #244 from dance12r/alpha
(SergeJey)
FIX function 'ask'
https://github.com/sergejey/majordomo/commit/5d2d6...
19.07.2018
Updates
(SergeJey)
Updates
13.07.2018
Updates
(SergeJey)
Updates
Обсуждение (2) (3)
13.07.2018
Merge pull request #243 from Alexandr-logrus/Alexandr-logrus-patch-1
(SergeJey)
Update MajordomoApplication.php
https://github.com/sergejey/majordomo/commit/bcb85...
12.07.2018
Merge pull request #242 from savenko-egor/alpha
(SergeJey)
Fixed problem with zero date in DB dump.
https://github.com/sergejey/majordomo/commit/555cc...
10.07.2018
(SergeJey)
https://github.com/sergejey/majordomo/commit/f3be9...
09.07.2018
Merge pull request #240 from tarasfrompir/alpha
(SergeJey)
Добавлена картинка лого модуля - Устройства онлайн
https://github.com/sergejey/majordomo/commit/7db31...
09.07.2018
Updates
(SergeJey)
Updates
Обсуждение (1) (2)
02.07.2018
Admin fixes
(SergeJey)
Admin fixes
Обсуждение (1) (3)
28.06.2018
Fix
(SergeJey)
Fix
Double logicAction call fix
https://github.com/sergejey/majordomo/commit/ce560...
26.06.2018
Library fix
(SergeJey)
Library fix
https://github.com/sergejey/majordomo/commit/fc82f...
26.06.2018
JS libraries fixes
(SergeJey)
JS libraries fixes
https://github.com/sergejey/majordomo/commit/327ed...
26.06.2018
jQuery/jQueryMobile upgrade
(SergeJey)
Latest versions of jQuery/jQueryMobile 3rdparty libraries
https://github.com/sergejey/majordomo/commit/943e8...
25.06.2018
Fancybox update
(SergeJey)
Fancybox update
Fancybox jquery plugin update (also moved to 3rdparty folder)
https://github.com/sergejey/majordomo/commit/52029...
Обсуждение (1) (1)
25.06.2018
Merge pull request #227 from YuriiRadio/patch-5
(SergeJey)
Update ua.php
https://github.com/sergejey/majordomo/commit/4e332...
23.06.2018
Merge pull request #233 from tarasfrompir/patch-4
(SergeJey)
Мелкое исправление функции создания простых устройств
https://github.com/sergejey/majordomo/commit/2db72...
20.06.2018
Updates
(SergeJey)
Updates
Обсуждение (1) (1)
13.06.2018
Merge pull request #230 from YuriiRadio/patch-6
(SergeJey)
Маленькая оптимизация
https://github.com/sergejey/majordomo/commit/46ae1...
12.06.2018
Simple Devices: motion fix
(SergeJey)
https://github.com/sergejey/majordomo/commit/3514e...
12.06.2018
Updates
(SergeJey)
Updates
11.06.2018
File remove
(SergeJey)
File remove
Added by mistake :)
https://github.com/sergejey/majordomo/commit/59de1...
11.06.2018
Updates
(SergeJey)
Updates
Обсуждение (1) (2)
11.06.2018
Merge pull request #229 from fsa/pdo
(SergeJey)
Взаимодействие с базой данных через PDO.
04.06.2018
Updates
(SergeJey)
Updates
  • Simple Devices: general sensor added
04.06.2018
Connect Sync fix
(SergeJey)
Connect Sync fix
  • SSL check removed
01.06.2018
Minor updates
(SergeJey)
Minor updates
  • copyTree procedure update
  • thumbnail generator debug mode update
30.05.2018
Updates
(SergeJey)
Updates
  • Simple Devices: intefrace fixes
  • Simple Devices: addons support (add new device types with 3rd party scripts)
27.05.2018
Updates
(SergeJey)
Updates
  • DebMes file limit (with config option)
  • Scenes fix (fancybox script added)
  • LoadFile minor fix (checks file to exist)
26.05.2018
cycle connect fix
(SergeJey)
cycle connect fix
Cycle connect startup check fixed
24.05.2018
(SergeJey)
24.05.2018
Merge pull request #224 from YuriiRadio/patch-4
(SergeJey)
Update ua.php
22.05.2018
Diagnostic script update
(SergeJey)
Minor updates to diagnostic data collecting script
21.05.2018
(SergeJey)
20.05.2018
Merge pull request #222 from palacex/alpha
(SergeJey)
fix: initialize array
18.05.2018
Folders attributes fix
(SergeJey)
  • Fixing incorrect attributes on startup when moving folders
  • Simple devices user's interface update
17.05.2018
FreeBoard fix
(SergeJey)
FreeBoard fix
Javascript path fix (some functions were broken).
16.05.2018
Minor fixes
(SergeJey)
Minor fixes
15.05.2018
(SergeJey)
Simple Devices user's section update -- swipe interface added with filter option.
14.05.2018
Startup folders check fixed
(SergeJey)
14.05.2018
Merge pull request #219 from palacex/fix-wrong-cached-dir
(SergeJey)
Fix wrong cached and debmes dir
14.05.2018
Diagnostic fix
(SergeJey)
Diagnostic fix
Diagnostic script not working when main cycle was stopped - Fixed.
Обсуждение (2) (1)
13.05.2018
Merge pull request #217 from palacex/fix-cycle-warning
(SergeJey)
Add check for mqtt application exist then cycle_connect.php started
12.05.2018
(SergeJey)
12.05.2018
Merge pull request #216 from palacex/alpha
(SergeJey)
Fix missing pwd/config.php and htmlMimeMail constructor
12.05.2018
Diagnostic data sharing
(SergeJey)
Ability to share diagnostic data for additional support
Обсуждение (1) (1)
11.05.2018
Connect/Market fix
(SergeJey)
Connect/Market fix
Changing to https in connect/market urls
08.05.2018
Organizing files
(SergeJey)
Organizing files
Moving 3rd-party libraries and products out of the main folder (to /3rdparty/).
08.05.2018
Merge pull request #215 from palacex/alpha
(SergeJey)
Fix: Parse error after auto-formatting source with a condition in the template (jtemplate)
04.05.2018
Minor updates
(SergeJey)
Minor updates
  • Classes import fix
  • Some warnings fixed
  • Modules constructor function rename
02.05.2018
New languages
(SergeJey)
New languages
  • Polish language added
  • Czech language added
28.04.2018
Import/Export updates
(SergeJey)
  • Menu and Classes import/export updates
  • Market custom import fixes
  • Alt. class templates support added
27.04.2018
Devices updates
(SergeJey)
Devices updates
  • Simple Devices -- counter device update, chart update
Обсуждение (1) (3)
25.04.2018
Settings fix and Simple Devices update
(SergeJey)
  • Settings: incorrect field when updating settings
  • Simple Devices: power monitor timeout setting
23.04.2018
General Settings update
(SergeJey)
  • Remove not-used settings
  • Help hints added
  • Ability to set "hooks" priority
Обсуждение (2) (2)
20.04.2018
Estonian language
(SergeJey)
Estonian language
  • Estonian language added
  • cycle_execs minor fix
19.04.2018
Merge pull request #209 from palacex/master
(SergeJey)
Ок. перенес
19.04.2018
Merge pull request #207 from rgubin/patch-1
(SergeJey)
Add ability to get LOCATION property of object
10.04.2018
Simple Devices help tips added
(SergeJey)
Added info (help) signs to get additional information on settings available for Simple Devices
Обсуждение (0) (4)
09.04.2018
(SergeJey)
  • Module manual upload added
  • Auto-import support added for addons
  • install.php support added for addons
Обсуждение (2) (4)
03.04.2018
Interface tweaks
(SergeJey)
Interface tweaks
Minor interface tweaks
03.04.2018
Animated GIF helper class
(SergeJey)
Обсуждение (3) (3)
03.04.2018
Cameras takeSeries
(SergeJey)
Cameras takeSeries
  • Simple Devices: takeSeries method added for IP cameras (getting animated snapshot)
  • Simple Devices: takeSnapshot fix (transport setting was not applying)
  • Properties: history processing fixed for expiring data with linked files
02.04.2018
Scripts section update
(SergeJey)
  • Import/Export scripts
  • Search filter
  • Recenlty updated list
Обсуждение (1) (3)
02.04.2018
Fixes
(SergeJey)
Fixes
  • Data processing in Control Panel fixed
  • Minor optimization of pChart index script
  • Removed some unused php files
01.04.2018
Merge pull request #194 from Gelezako/patch-2
(SergeJey)
раскрытие информации о конфигурации сервера
27.03.2018
Simple Devices updates
(SergeJey)
  • New load types: ventilation/heating/curtains
  • Ability to set custom icon for switches and buttons
Обсуждение (5) (3)
27.03.2018
Updates
(SergeJey)
Updates
  • Panel layout and links minor changes
  • cycle_phistory.php added for history queue processing
Обсуждение (3) (3)
23.03.2018
Merge pull request #193 from sergejey/master
(SergeJey)
Alpha update
23.03.2018
Control Panel minor fixes
(SergeJey)
  • News section fix
  • Javascript error loggin fix
22.03.2018
Updates
(SergeJey)
Updates
  • Icons for modules added
  • Blockly mode activated by default for new scripts
  • Simple Devices: Counter updated (work_value, hourly, daily, monthly graphs)
  • Simple Devices: Power sensor updated
  • Market: scheduler module uninstall fix
Обсуждение (2) (2)
20.03.2018
Control Panel interface updates
(SergeJey)
  • General layout update
  • Home page update
Обсуждение (0) (8)
18.03.2018
Merge pull request #183 from Anisan/alpha
(SergeJey)
update view admin panel
Обсуждение (0) (5)
08.03.2018
Updates
(SergeJey)
Updates
  • Simple devices minor changes
  • Menu fixes
27.02.2018
Market Fix
(SergeJey)
Market Fix
"Have updates" flag fix
27.02.2018
Merge pull request #180 from olehs/patch-5
(SergeJey)
terminal LATEST_REQUEST
26.02.2018
Background exec for Windows fix
(SergeJey)
25.02.2018
PHP 7 authorization fix
(SergeJey)
25.02.2018
PHP7 fix
(SergeJey)
PHP7 fix
25.02.2018
PHP7 fix
(SergeJey)
PHP7 fix
22.02.2018
Menu fix
(SergeJey)
Menu fix
20.02.2018
Menu fix
(SergeJey)
Menu fix
Fixing objects update behavior in menu
19.02.2018
Languages added
(SergeJey)
Languages added
  • Romanian language
  • Latvian language
16.02.2018
Updates
(SergeJey)
Updates
  • Scenes: conditional view for containers
  • Settings: not used items removed
  • Simple Devices: night mode removed
  • Objects Tree: method link fixed
  • Menu: auto-update for TimeBox item fixed
  • Market: "ignore update" option fixed
05.02.2018
Merge pull request #176 from Gelezako/patch-1
(SergeJey)
Исправление локализации
29.01.2018
Dashboards fix
(SergeJey)
Dashboards fix
CSS problem for simple devices in dashboards fixed.
28.01.2018
Merge pull request #168 from Anisan/alpha
(SergeJey)
Simple devices motion timeout
Обсуждение (3) (1)
26.01.2018
New languages and minor fixes
(SergeJey)
  • Bulgarian language (new)
  • Ukrainian language (fixes)
  • Lithuanian language (fixes)
26.01.2018
Menu fix
(SergeJey)
Menu fix
25.01.2018
Updates
(SergeJey)
Updates
Bug fixing
30.08.2017
Обновления
(SergeJey)
Загружено обновление в альфа-ветку.
  • Новый тип данных для свойств -- Изображение. Можно устанавливать через setGlobal и в качестве значения указывать ссылку на изображение или путь к файлу. Поддерживается сохранение истории.
  • Новый тип Простых устройств -- Камера.
30.08.2017
Обновления
(SergeJey)
  • Новая опция в config.php SEPARATE_HISTORY_STORAGE -- если она установлена, то история свойств объектов будет храниться в отдельных таблицах для каждого свойства. После изменения этой опции надо перезагрузить систему, что бы данные разбились на отдельные таблицы. Сборка назад точно так же -- убрать опцию, перезагрузить систему
  • Новые функции для работы с событиями, комнатами и устройствами через API. Подробнее здесь: http://majordomo.smartliving.ru/Main/Urls
  • Модуль События -- теперь он видимый в панели управления (раздел Система) и может быть достаточно полезным через функцию registerEvent или API -- если названия событий разделять обратным слэшем (path/to/event), то в интерфейсе события будут группироваться деревом. Ну и к параметрам событий можно привязывать свойства объектов.
  • В простых устройствах небольшие обновления -- индикатор датчика открытия теперь учитывает тип (NormalOpen/NormalClose), время срабатывания датчиков движения теперь в более удобном формате.
Обсуждение (1) (1)
(43)
Подписаться на обновления (123)
Jon811 255.68
irisbar82 30.00
ddd0251
спасибо за восстановление
2,000.00
Anonymous
Внесу свой скромный вклад
300.00
Чтоб МДМ стоял и деньги были...
200.00
Mikhail1653 200.00
Mikhail1653 200.00
Mikhail1653 100.00
Mikhail1653 100.00
Mikhail1653 100.00
15 причин пересобрать инсталлятор MajorDoMo для Windows +51
Простые устройства и их создание +35
Доработать визуальный интерфейс управления простыми устройствами +29
приоритеты отправляемого на терминалы контента +22
Ошибка если в названии объектов есть дефис +16
Простые устройства: Отдельный проект +16
Добавить логирование изменений свойств ПУ в журнал действий пользователей +16
Не работает pChart analog +15
После обновления ядра 09.01.2020 сломалась callMethodSafe() +15
разделы (папки, категории, группы) для СЦЕН под различные дизайны и устройства. +13
не работает функция SendMail +12
Обновление модуля MegaD +12
выбор ссылки или приложения домашней страницы +12
Простые устройства: Невозможно выставить aliveTimeout 5 минут +11
Шаблоны поведения, галки по умолчанию +11
Запретить удалять ThisComputer, ClockChime +11
Интеграция с сервисом IFTTT +10
Не коректное отображение выбора RGB +10
пинг-онлайн +10
ModBus TCP работа с сетью. +10
Об $original в шаблонах +10
replyTo говорит во все терминалы, если запрос пришел не с MajorDroid (а из хрома, например) +9
Некорректное озвучивание датчика протечки воды +9
При переходе системы по паттернам возникает их задвоение +9
Невидимый selectbox в темной теме +9
Логин (вход) в систему +9
Неверное окончание в локализации для простых устройств +8
Восстановление не нужныж таблиц БД при железном рестарте системы +8
Простые устройства: Векторные иконки +8
Простые устройства: Диммер +8
Добавить функцию установки модулей из маркета +8
Простые устройства Телевизор +8
Убрать веб-переменные из ядра в маркет +8
Сделать проверку alive отключаемой +8
Открываемое (Ворота/Двери/Шторы/и т.п.) +8
БАГ имена методов объектов +7
Изменение логики в Датчике движения +7
Двойное вызов logicAction сенсоров +7
Управление яркостью экрана Majordroid +7
Плюс-минус через коннект +6
Настройка +6
Редактировать название в простых устройствах +6
Дополнительный функционал +6
Простые устройства +6
Отключение базового резервного копирования +6
Старые пути и ссылки на отсутствующие файлы +6
Панель управления / settings +6
Текст статусов для выключателя не сохраняется +6
Проговаривание фраз по два раза +6
Настройка Диндона +6
Шаблоны поведения +6
Добавить возможность дополнительного шаблона отображения объекта и вызова сервисного меню +6
backup startup_maintenance.php +5
Баг: Перестаёт работать панель управления +5
XSS in modules\thumb\enlarge.php +5
Ошибки при обновлении .htaccess на ОС Windows +5
Проверить тайминги на сохранение бд +5
Меню Текстовое поле +5
Добавить проверку на наличие непривязанных методов к классам и объектам методов и производить их зач +5
autodiagnostics +5
Унифицировать кодировку в x-ray/логах +5
Модль bluetooth +5
Унификация функций getObjectsByClass и getObjectsByProperty +5
Контроль за целостностью системных объектов, свойств и методов +5
Добавить для выключателя свойство readonly +5
Показывать кол-во обновлений в ПУ +5
[Сцены] Время анимации элементов +5
ошибка clearScheduledJob -2 +5
GPS tracker добавить цвет пользователю +5
Дать возможность задавать ширину и высоту типу device в сценах +5
Простые устройства "Датчик CO2" +5
код метода не скрывается под шапкой страницы +4
Фильтрация значений +4
_javascript_errors.log +4
Контроллер MegaD 2561 и поддержка расширителей портов. +4
не правильно стали отображаться switch и warning они обрезаются в сценах. +4
ошибка Термостата в ПУ +4
добавить автоматическую очистку таблицы project_modules +4
Ошибка в билдере модулей +4
Переписать функции инсталяции-деинсталяции модулей +4
добавить возможность комментировать в Объектах поле Свойство +4
Запросы с X-Ray +4
автоматические добавление настроек свойств для optimizer +4
БАГ имена методов об +3
Обновление пакетов модификаций +3
По непонятной причине раз в год отвязывают счёт методы от объектов. +3
Битая кодировка. +3
Увеличить размер сценария в Before PlaySound (code): +3
Вылетает метод, привязанный к require(DIR_MODULES.'devices/nightmode_deactivate.php'); +3
не стартует цикл Connect +3
ОпенКлосе и Броадлинк +3
таблица blockly_code +3
При попытке обновить модуль установленный вручную - ошибка +3
Вывод пу на сцены +3
Некорректное оповещение в ПУ Датчик температуры+влажности +3
вывод less +3
ChromeGateMJD +3
Простые устройства +3
Картинка не найдена gritter.png 404 (Not Found) +3
Унификация логов - дата и время +3
Добавить пиктограмму приложений в маркете +3
обработчик отсутсвия прав на папку +3
MegaD и модуль MegaD devices + ПУ +3
"Значение по умолчанию" для свойств класса-объекта +3
periodical_db_save.php - ошибка формирования пути к дампу базы +3
В панели управления для кнопки невозможно прописать условие ее отображения +3
Панель управления / users добавить инфополе ID +3
При обновлении системы выдавать предупреждение: "файл не обновлен" +3
Добавить в шаблоны поведения категории +3
Довести до логического завершения модуль dashboard +3
Планы - выбор стилей +3
Не работает фильтрация на вкладке debug в xray +3
Выделить в админке что появились обновления для модулей +3
Автоматическая очистка метода motionDetected() +2
Удвоение циклов. +2
Не работает импорт пунктов меню +2
Добавить в шаблоны сравнение через equalsIgnoreKeys() +2
Логи занимают слишком много места. +2
На линуксе не отображаются карты яндекса +2
Новый метод у объекта +2
косяки в меню +2
Сделать в меню динамичную иконку +2
HomeKit выбор устройств +2
Авто-повтор в меню +2
при редактирование элемента на сцене: опция "расширенная настройка" убивает привязку устро... +2
callAPI не принимает $params +2
Групповое удаление объектов и пунктов меню +2
Объекты и сценарии +2
Модуль "Мои блоки" +2
Контроль доступа - пользователь Anonymous +2
Добавить предупреждение о скором наступлении режима Никого нет дома +2
В Маркете дополнений выделить новые модули +2
Регулярно пропадают элементы со сцены +2
Ошибка в маркете дополнений +2
Разделы системы для регулярного резервного копирования +2
Простой термостат +2
Обновление системы +2
Счётчик электроэнергии по тарифам в зависимости от времени суток +2
Оять перестала растягиваться сцена на полный экран. +2
увеличить ширину формы шаблонов отображения для объектов +1
Системная история событий +1
Не открываются настройки сцен +1
error clearScheduledJob 2 ((( +1
снова db_terminal.sql. красная шестеренка, остановленные циклы. +1
Смена цвета SRGB на iOS в приложение "Мой дом" +1
Доделать модуль Энергомера +1
убрать сообщение "неизвестная комманда" +1
Выключение димера через свойство Status +1
После обновления ядра после нового года сломалась выпонение некоторых строк в onnewminute +1
Ошибка сохранения свойств элементов на сцене +1
Перестали выполняться команды при значении в ПУ "Изменение означает активность в помещении... +1
Ошибка в поле Шаг изменений панели управления +1
Двойное удаление(( +1
в цикле постоянно выполняется getObject('Computer.ThisComputer'), а там же это начитано в... +1
Некорректное поведение информеров в сценах при выборе доп. состояний. +1
Информация в src для джобов не информативна +1
крайнее обновление MJD перестал работать MQTT +1
Элемент сцены - датчик движения +1
Не правильный путь к иконкам статусов +1
Не срабатывают шаблоны поведения из родного чата +1
Too large squares background icons +1
Зачем переделывать update на параметры? +1
Поддержка датчиков пыли ПУ +1
Путь к объекту в шапке страницы раздела [Объекты] +1
Датчик открытия SNZB-04 включает ТВ и RGB ленту через Tuya IR +1
шапка админки +1
поиск в мобильном браузере +1
История свойства объекта +1
Feature request: transient свойства объектов +1
Просьба подкорректировать документацию в файле html/pChart/index.php +1
ПУ датчик освещенности не работает. +1
Векторные иконки (*.svg) +1
TV Глаз.ТВ 0
пустрые значения в таблице pvalues 0
Двоение свойств в простых устройствах 0
Падение своего цикла при исполнении шаблона поведения 0
Простые устройства: датчик открытия постоянно обновляет статус 0
Ошибка авторизации для входа в Панель управления на мобильном через мажордроид и через браузер 0
Не сохраняет базу на raspberry pi с включенной оптимизацией циклов записи 0
Местоположение и названия комнат 0
модуль Modbus: линковка 0
Table 'majordomo_db.actions_log' doesn't exist 0
HOOK_BEFORE_SAY никогда не выполнится для say от юзера 0
Values don't fit on the chart 0
modules/objects/objects.class.php - ошибка 0
cycle.php 0
Ошибка 0
load_settings.php 0
custom_error && msqli.class.php param stop issue 0
оналйн-радио app_radio.class.php 0
Это для php7. А есть где то требования к софту для работы МЖД? 0
задержка запуска джобов 0
Упрощение 0
Упрощение нагруженной функции getObject 0
Упрощение loadObject 0
Лишняя и неверная запись в бд поля TITLE 0
Регулярка не работает для Винды( 0
поле value не описано 0
Путь к mysql прописан хардкодом в Windows( 0
Ошибка при выполнении cycle.php 0
битая кодировка в файле 0
common.class.php 0
objects.class.php - модификация функции setProperty 0
Feature request: load_settings.php 0
Feature request: objects.class.php - модификация функции setProperty 0
А зачем эта строка 0
wrong module name 0
Errors in cycle.php -1
инсталяция и разделение фунций умного дома -4
Ошибка при исполнении метода. -4
Дополнение ZigbeeDev
Дополнение YaDevices
Дополнение HA Discovery
Дополнение MQTT
Модуль Ноолайт
Дополнение MegaD devices
Дополнение Tapo
Дополнение Earthquakes
Дополнение Текстовый календарь
Дополнение GPT chat
Дополнение Charts
Дополнение Zont
Дополнение ADB control
Дополнение Homekit
MajorDoMo-doc
Дополнение Wirenboard
Дополнение WebVars
Модуль XiaomiHome
Базовый образ для RPi-RTC-PoE
Дополнение SQLMeter
Дополнение ATV Notifications
Дополнение Jitsi
Дополнение USRIoT
Интеграция Google Home
Графические Планы
Дополнение MiLight
Дополнение VPNki
Дополнение SMTP Catcher
MajorDroid
Простые Устройства (ПУ)
Дополнение LivoloRemote
Интеграция Google Assistant
Дополнение Insyte
Модуль Optimizer
Веб-сайт CONNECT
Дополнение Zipato
Поддержка на форуме
YouTube-канал MajorDoMo
