Дополнение MegaD devices
Поддержка устройств MegaD (http://ab-log.ru)
07.02.2026
Update megaddevices_search_admin.html
(SergeJey)
Online status indication
https://github.com/sergejey/majordomo-megad/commit...
05.08.2025
Update megaddevices_edit.inc.php
(SergeJey)
18.12.2024
Update readvalues.inc.php
(SergeJey)
Pressure data support
14.09.2024
Minor updates
(SergeJey)
Minor updates
01.12.2023
(SergeJey)
14.07.2023
SCD4x sensor support
(SergeJey)
07.05.2023
(SergeJey)
20.08.2022
Tools update
(SergeJey)
Tools update
12.08.2022
Remote config fix
(SergeJey)
Remote config fix
11.08.2022
Updates
(SergeJey)
Updates
06.08.2022
Dust sensor support
(SergeJey)
Dust sensor support
08.07.2022
MegaD-16PWM-I2C support
(SergeJey)
09.03.2022
Fixes
(SergeJey)
Fixes
20.02.2022
I2C PTsensor support
(SergeJey)
17.12.2021
Device Config tab fixes
(SergeJey)
24.08.2021
Fixes for 16i_xt module
(SergeJey)
Обсуждение (1) (0)
21.08.2021
MegaD-16-IR-XT support added
(SergeJey)
15.05.2021
Update megaddevices_search.inc.php
(SergeJey)
Support of quick navigation to linked object/property
14.08.2020
Config fixes
(SergeJey)
Config fixes
Fixes related to inner config section
14.08.2020
Port delete fix
(SergeJey)
Port delete fix
Port delete fix
06.07.2020
Update megad.class.php
(SergeJey)
request processing fix
05.07.2020
Added support of MegaD-16I-XT
(SergeJey)
27.06.2020
Minor fixes
(SergeJey)
Minor fixes
01.04.2020
Update megad-cfg.php
(SergeJey)
15.01.2020
(SergeJey)
Minor config fix
13.12.2019
(SergeJey)
12.12.2019
Update megad.php
(SergeJey)
Update megad.php
27.11.2019
Updates
(SergeJey)
Updates
Обсуждение (1) (0)
23.09.2019
(SergeJey)
Minor fix
17.09.2019
Merge pull request #11 from directman66/master
(SergeJey)
Добавлены остальные файлы.
16.09.2019
Merge pull request #10 from directman66/patch-1
(SergeJey)
12.09.2019
Update megad.php
(SergeJey)
Update megad.php
Minor fix
21.08.2019
Reverse mode for IN/OUT
(SergeJey)
21.07.2019
Debug log update
(SergeJey)
Debug log update
Now requests to devices getting saved to the log when log is turned on.
19.07.2019
Device config update
(SergeJey)
Help added
19.07.2019
Merge pull request #8 from directman66/master
(SergeJey)
Добавлено управление устройством через web из админки модуля
18.07.2019
Merge pull request #7 from directman66/master
(SergeJey)
Add icon
19.04.2019
(SergeJey)
ReadValues after sending command removed.
26.03.2019
(SergeJey)
Removed unnecessary update operation
15.03.2019
Fixes
(SergeJey)
Fixes
10.02.2019
Update
(SergeJey)
Update
09.02.2019
Update megaddevices_edit_property.html
(SergeJey)
Device preview support added
01.02.2019
Negative values fix
(SergeJey)
Negative values fix
Fixing reading negative values for temperature/humidity
31.01.2019
Updates
(SergeJey)
Updates
Обсуждение (2) (2)
28.01.2019
Updates
(SergeJey)
Updates
28.01.2019
Merge pull request #4 from sergejey/alpha
(SergeJey)
Alpha
28.01.2019
Merge pull request #3 from sergejey/alpha
(SergeJey)
Alpha
(17)
Подписаться на обновления (24)
Не распознаётся конфигурация порта NC +15
Дополнение не умеет корректно работать с расширителями MegaD MCP23017. +12
1wire устройства шиной не читаются. +6
Модуль не обрабатывает событие long_press +6
После обновления модуль перестал обрабатывать изменения свойства привязанного объекта +5
Отображение ненужных данных +5
Добавить обработку входящих СМС +4
Обновление портов +4
Перестали работать физические кнопки (обновление 27.11.2019) +3
Дополнение для синхронизации времени устройств c mjdm +3
Датчик температуры микросхемы Mega328 +3
Не корректно обрабатываются сценарии по умолчанию с знаком | в тексте +2
Добавьте пожалуйста поддержку MegaD-2W +2
Датчик BMx280 +1
SMS 0
Модуль не находит устройства при нажатии кнопки сканировать 0
Некорректная работа через инет. 0
Дополнение MQTT
Дополнение YaDevices
Дополнение ZigbeeDev
Модуль Ноолайт
Дополнение HA Discovery
Дополнение Tapo
Дополнение Earthquakes
Дополнение Текстовый календарь
Дополнение GPT chat
Дополнение Charts
Дополнение Zont
Дополнение ADB control
Дополнение Homekit
MajorDoMo-doc
Дополнение Wirenboard
Дополнение WebVars
Модуль XiaomiHome
Базовый образ для RPi-RTC-PoE
Дополнение SQLMeter
Дополнение ATV Notifications
Дополнение Jitsi
Дополнение USRIoT
Интеграция Google Home
Графические Планы
Дополнение MiLight
Дополнение VPNki
Дополнение SMTP Catcher
MajorDroid
Простые Устройства (ПУ)
Дополнение LivoloRemote
Интеграция Google Assistant
Дополнение Insyte
Модуль Optimizer
Веб-сайт CONNECT
Дополнение Zipato
Поддержка на форуме
YouTube-канал MajorDoMo
