Владелец задачи: nick7zmail, Екатеринбург - Россия
Текущий статус:
Поддержка
Основная тема: http://majordomo.smartliving.ru/forum/viewtopic.ph...
Модуль на гитхабе: https://github.com/nick7zmail/MajorDoMo-dev_broadl...
Доработка и поддержка модуля.
Merge pull request #29 from whitevast/master
Добавлена поддержка RM4PRO
Merge pull request #28 from vitt76/fix/broadlink-cycle-count-error
Fix: Исправлена ошибка count() в PHP 8+ и инициализация переменных
Merge pull request #27 from whitevast/master
Исправлен режим обучения
Merge pull request #25 from whitevast/master
PHP8 fixes
Merge pull request #23 from mosave/master
Добавлена возможность проверки доступности устройств перед опросом
Merge pull request #21 from mosave/master
Доработка синхронизации текущего времени на термостате
Merge pull request #20 from mosave/master
HYSEN: get_status buffer validation & concurrency issue workaround
delete commands fix
delete commands fix
LearnForm Updated
LearnForm Updated
cloud fix
cloud fix
cloud work directory fix
code generator fix
code generator fix
some models RM add
some models RM add
RM Pro+, RM3 mini
Merge pull request #17 from olehs/master
Zero-Temp on error fixed
Merge pull request #16 from olehs/chechvals
Values Checking fixed
Merge branch 'master' of https://github.com/nick7zmail/MajorDoMo-dev_…
Merge branch 'master' of https://github.com/nick7zmail/MajorDoMo-dev_broadl...
Merge pull request #15 from indimouse/master
Support Hysen WiFi thermostat devices
Merge pull request #14 from xor2016/patch-1
Update dev_httpbrige_devices_edit.inc.php
cloud fix + new periods add
Revert "cloud fix + new periods add"
This reverts commit 7741451387795fcf0e296ebe3cefad3b86262577.
Merge pull request #13 from micro3x/master
Fix for downloading individual item from cloud and fix for ×tamp…
Merge pull request #12 from olehs/master
encrypt/decrypt fix
mcrypt to openssl migration
Исправлена работа с php7.1+, изменена утилита шифрования с mcrypt на openssl.
Dooya fixes
Dooya fixes
Поправка для карниза dooya при крайних положениях
Оптимизация
Добавлена функция разбиения команд РМ на страницы.
Автоматическое обновление IP
Подробнее: http://majordomo.smartliving.ru/forum/viewtopic.ph...
Экспорт команд из облака
Добавлена возможность экспортировать команды из облачных бэкапов.
Облачные функции
Добавлен интерфейс работы с облаком Broadlink (основная возможность - скачивать бэкапы).
Функции MS1 и SP3S
В SP3S добавлена функция опроса мощности.
В MS1 добавлены кнопки - play, pause, prev, next, vol+, vol-, aux.
Функции MS1
Добавлены некоторые функции для интеграции колонки MS1 в систему. Сейчас доступно:
-Выключение колонки
-Функция заглушения (Mute)
-Изменение громкости
Добавлены устройства, исправлена ошибка с 249 градусами в RM
Добавлены некоторые новые (и старые, ранее неподдерживаемые) устройства из e-control. Добавлены только в автоматическое сканирование...это не значит что они все и сразу заработают)) Работоспособность нужно добавлять/настраивать для каждого устройства индивидуально.
Так же исправлен случай, когда в историю температуры RM попадало число 249. Теперь данная температура просто не записывается...т.к. это случается крайне редко - при следующем обновлении должно прийти корректное число.
Поддержка SP3S
Добавлена поддержка sp3s (пока без запроса мощности), исправлен 10-минутный цикл.
Устранено периодическое выключение/сбрасывание параметрах на исполняющих устройствах, в случае, если устройство недоступно.
В первую очередь касается S1, MP1 и розеток SC. Было связано с тем, что в момент недоступности устройства (по каким-либо причинам, связанным с сетью, либо другими устройствами) в качестве ответа возвращался пустой массив, что в последствии вело к выставлению всех свойств в 0. Выставление свойств в 0 система воспринимала, как действие пользователя, и отправляла соответствующий отклик на устройство, ну и устройство выключалось/сбрасывало текущий статус.
Поддержка устройства S1
Полная поддержка S1 с периодическим запросом статуса датчиков.
